About a week ago my lamp died so I replaced it. Two days later the fan was giving me problems so I cleaned it and it worked perfectly for a couple weeks. Now when I turn it on, all I get is a black screen with a vertical bar on the left side. The bar is a greenish color and is made up of a few different shades of smaller vertical green bars. When I press the menu buttons, nothing happens. Basically the TV just stays like this and all I can do is turn it off. It's stuck on input 4 (RGB + audio) and the audio DOES work.
I have it completely opened up and I'm an engineer so don't be afraid to speak in techy terms. Where do I start? Right now I'm looking at the connection between the lamp control board and the giant video processor board. I know everything else works because I've tested most everything else (fans, power supply, sensors, inverters).
Thanks in advance!
Thanks in advance!
