AVS › AVS Forum › Audio › DIY Speakers and Subs › Ficar SSD18 Group Buy Thread
Ficar SSD18 Group Buy Thread - Page 18
post #511 of 535
Originally Posted by bossobass View Post
I had a sneaky suspicion this was the case, as it sometimes is when you build something very specific.
LMK if there's any way I can help. I spent a good deal of time making sure the stacking hardware and system would be stable, accurate and durable. Cant' have a stack of 8-15s leaning off its center of gravity
Glad to see you're still at it... I was gettin' worried there.
Bosso
Thanks, much appreciated!
post #512 of 535
Awesome!
Which mic (cap/cartridge) did you get? Why would it need to be calibrated? What friggin' mic would you use to calibrate an ACO Pacific mic?
I have the 7012, same cap that's in the B&K 4133 that was used to calibrate Ilk's IBF Akustik EMM-8.
Did you get the SPL calibrator?
Thanks for the heads up... very cool. Now if I request data below 10 Hz, I'll know it's accurate.
Bosso
A 7012 with 4012 preamp and a 511E calibrator. I'm having everything recalibrated by ACO and the power supply modifed a little. I also picked up a G.R.A.S. 40AM prepolarized capsule , which is the company founded by a few of the guys that defected from B&K when it was bought. They make precision capsules and preamps as well. Really good stuff. A 4048 preamp that I can use with a 48v source if I want to use a precision measurement mic without having to have the whole kit, a 4212 pre so I can use the 40AM with the 9200PS, etc...
post #513 of 535
"Why do you ask?"
i was kind of wondering if the peak in some the recently measured subs behaves in the time domain similarly to the way a room mode does or not.
That's what I thought you were getting at.
First, you can't eliminate a room mode with EQ. You pull down the peak with EQ, but you don't eliminate the stored energy. That's why you still see it in a waterfall graph.
A notch in the signal to the subs naked FR is a different situation. The peak from high inductance is not stored energy. It's what's left after the roll off above it.
I have disagreed with Seaton's 'fingerprint' theory simply because I've never seen any evidence of it. He says it rears its head when you 'push the sub to its limits', but any number of bad things (and/or changes caused by design, such as limiting) can happen anywhere in the chain when you do something like that.
In any case, I've heard dozens of subs in my room over the past 20 years. If there was any sort of ringing from the SSD-based subs, I would have heard it, rejected the design and not have ever suggested the SSDs to anyone.
On the contrary, other than lacking a few dBSPL below 20 Hz compared to other systems I've built using longer throw, lower Fs drivers, the system kicks serious a$$.
The Tumult MKI (and several other overhung, long throw, low Fs drivers I've used) rolled off -8dB from 50-100 Hz and I never experienced ringing after L/T signal shaping. (Instead of a notch, I used the L/T to treat the peak as a high Q sub, which gives a similar end result, but the price is that the L/T extends to above 200 Hz).
When most people say a sub is 'tight', they're usually referring to the fact that there is no low end. When I refer to a system as sounding 'tight', I'm invariably referring to the fact that there's no audible ringing because every system I design is flat to 4 Hz in my room.
I've read various opinions about high Q ringing and have since dismissed them as irrelevant to the 'after' notch with L/T response and its performance. When my systems are pushed to their limits, it's always below 20 Hz where the heaviest L/T boost is. Where the notch is, the system is doing the back stroke. Otherwise, you've designed a seriously flawed system.
Bosso
post #514 of 535
Now you're talkin'. I have the same ACOPacific system (7012, 4012, PS9200 and calibrator) since '04. When REW expanded to 2 Hz my whole world changed and then SpecLab added a whole new dimension.
Beyond reproach. Can't wait to read all about it. Congrats.
Bosso
post #515 of 535
My sentiments exactly...I don't know WTH I am getting until after it's already paid for with most sub drivers. At least the Pro drivers give you most of the relevant info... The reason that they do is because established companies actually use their products in finished for sale systems and the information is needed to select a driver for an app prior to trying it out for real. They aren't going to select something with little or incomplete information just to try it because it looks cool or has a great sounding list of parts. Many of the so called Hifi or home audio companies producing raw drivers operate the same way for the same reasons. Most of the big diameter long throw sub drivers (You know the kinds that all of us around here are interested in) are made by car audio companies or marketed to that market. Truth is that most of those buyers just buy a driver, slap it in a box recommended by the MFG and play...They have no idea what their final system response is or the box driver combo. Its all based on subjective reactions and hearsay from others of their subjective reactions. Large companies aren't buying these types of raw drivers to use in finished systems nearly as much. Since there is little demand for this information and few of their potential buyers would understand it if it were, it is not a concern of the manufacturers to get it out there. That's my 2 cent BS take on it anyway.
Well said, Bosso and Ricci. Couldn't have said it better, myself and a large reason why I'm so picky these days.
post #516 of 535
Eric I put your info for the PSI recone 13AV2 on the Dizzle-Bizzle site.
post #517 of 535
Hey! Alright! Been waiting for the updates.... and you snuck in the MX18 from RE.
post #518 of 535
That was a personal...It made me curious.
post #519 of 535
Ricci did you ever do tests seeing if you could hear the loud knocking noise of the Q18/Xcon in the 4 cu ft enclosure through the cone??
That knocking seems insanely loud.
post #520 of 535
"Why do you ask?"
just out of curiosity. there is a theory that suggests that once the frequency domain is fixed, the time domain will be fixed. period. however, this applies to some systems, "minimum phase" iirc, though i don't really understand what that is because i haven't studied fourier analysis.
i've seen in-room measurements where even after the frequency response has been flattened, there are still effects (for lack of a better word, i'll call them resonances) in the time domain and they show up in waterfall plots. this suggests "subs in rooms" violate the minimum phase model.
For the most part, issues below 100Hz are largely minimum phase, with some exceptions with long resonances, especially sympathetic, structural resonances. For such response issues, conventional EQ works very well. If you look into some discussions related to REW, you will see that taking the time to get the EQ to form a proper conjugate filter can make a noticeable difference vs. a response that is just in the ballpark.
A woofer's frequency response is entirely minimum phase, and correcting the frequency response does correct tails in the decay time. A decay type measurement will directly mirror the frequency response for subwoofers until you get into issues of pipe resonances and length/dimension resonances, which are often out of the subwoofer's operating band, but not always.
seaton has also spoken about this. he can be 'reserved' sometimes in his information sharing (understandable even if better than most), but has mentioned that even after applying eq to a system, there remains something of a sonic "fingerprint". my thinking is that "fingerprint" lies in the time domain. this suggests that "subs with eq" are not always minimum phase.
Once the peak is smoothed, a peaked/humped response from higher Le does not cause any time domain resonances. The bigger reason that high Le raises a flag is that the greater the Le, the more likely it will modulate with excursion. A changing Le means a changing frequency response around the inductance hump vs. coil position. This is not a certainty, nor an absolute. Once you see significant Le, then the next question is if it's a problem for your application, and how linear/consistent is that behavior. It is possible for a woofer to have significant Le, while also remaining fairly linear. The shorting ring Fi uses on the ID of the magnet is such a case where this mostly serves to reduce the increase in Le that typically occurs on incursion (due to more steel in the middle and around the coil).
This isn't all that different from BL linearity, where everyone likes to think of a driver perfectly following the small signal assumptions of T/S parameters out to Xmax. Woofers are often around 70% of specified Bl at Xmax and maybe 1/2 Cms. If you model such parameter changes, you can see these to be significant with the specific shape changes directly related to Fb, Qb and Le hump.
As bosso has pointed to many times, if you use 8-16 large woofers in most rooms, that change becomes rather insignificant. For those short of that or those who are using the full rated excursion potential of their woofers regularly, there will be some tell-tales between significantly different drivers. As Josh has been starting to report much more on, the self-noise of the driver's operation can make for yet another tell-tale fingerprint.
post #521 of 535
bosso, mark, thanks for the comprehensive replies.
post #522 of 535
As I've said before, there is no evidence. If you have that actual data, can you please post it?
Take a look at the SSD-15 dual opposed box. The notch is centered at 65 Hz. For 120dB @ 1M, you have approximately 8 mm of throw.
With Tumult MKI, the notch is lower due to a lower Fs. With prog sweeps, compare the high Le Tumult to the Flat to infinity LMS Ultra:
I have no reason to believe there would be a difference in the Tumults behavior with a notch in place, because, as I've said, I've seen no evidence of it in measurements or audibly. But, it certainly appears to me that the high Le driver in this comparison is the stable one as they're being pushed.
IOW, a) how do you push the driver to X-max at 65 Hz? You don't, regardless of how many drivers you use. So, sine wave testing isn't going to reveal this "fingerprint".
What I'm gathering from this is that it might be instructive to run a sine sweep, then run the same sine sweep while a 20 Hz sine, combined with the sweep, is pushing the driver to near X-max (or something around that) and look for a difference at the notch.
From my own experiences, I would have to guess that there will be a deviation in response anywhere BUT at the notch.
This should be simple enough to try, so I'll do it and post the results the next time I'm measuring stuff. If this isn't addressing the 'fingerprint' issue, what else might, in a format that we could at least see such a trend?
Bosso
post #523 of 535
Bosso
On the surface that thought makes sense to my pea brain. It would mimic playback of most movies where multiple signals of varying frequency are coming in at one time.
Thanks for doing this bosso!
post #524 of 535
Bosso
Would this result in some kind of Doppler effect occurring especially if you are pushing out higher frequency content?
Matt
post #525 of 535
You wouldn't see the effect with a sine wave sweep I don't think since that is only a single frequency at a time. This shifting of response shape would not show up since only a single frequency is measured at a time and at 40-80Hz there isn't usually a whole lot of excursion even at very high outputs as mentioned. You would need a more complex signal with higher frequency content on top of a low frequency carrier that provides a lot of excursion. This could show up as distortion, weird noises at excursion, or possibly shifting, or ???? Seems like John J also mentioned something about this long ago.
So how would this be tested? Generate a 16Hz-20Hz steady state sine to develop driver excursion and then run a sweep measurement through the system from 35-200Hz? Try varying levels of the low frequency tone for more or less driver excursion with varying levels of the upper bass sweep? Thoughts? Ideas? Stupid? (Edit I should have read the rest of Bosso's post first I see he is thinking the same thing.)
I actually think I might be able to pull this test off without too much trouble depending on whether I can get multiple programs to share the soundcard. I have multiple measurement or audio programs open all of the time but I haven't actually tried running the generator from one program in the background while running a test routine in another before.
post #526 of 535
thats what Bosso was stating, run a 20hz sine and then a sweep over top of it. So you guys seem to be on the same page
post #527 of 535
This is basically what I was suggesting.
You should not have a problem generating the LF tone from a different program and the sweep from REW at the same time. The mic will just pick up what's in the air.
I mentioned a sweep without the tone as a reference response. You would also have to test a driver with no Le hump vs one with and the one with after notch.
IOW,
a) Does the low Le driver behave differently in sweep vs sweep + tone?
b) Does the high Le driver behave differently in sweep vs sweep + tone?
c) Do the high vs low Le drivers behave differently in sweep + tone?
d) Does the high Le driver show this fingerprint when tested as above 'with notch' and, if so, at what excursion vs X-max?
Bosso
post #528 of 535
IOW,
Bosso
Right I didn't see that you had the same thought before replying. As Mark said it isn't necessarily about just the LE value. You can have a driver with a good amount of LE that still seems to control the change in inductance with stroke well. We need a couple of candidates. A driver with a ton of shorting rings and very low inductance. A driver with a shorting ring or 2 but a moderate amount of inductance nonetheless and one with no demodulation circuit at all and a lot of LE. Preferably all with similar stroke.
I don't really care about the EQ notch truthfully. I don't think it is going to show anything different tested with vs without, but I could be wrong. My gut tells me that the driving factor will be how much excursion the low frequency tone is asking the driver for more than how loud the upper bass sweep is. Again could be completely wrong though. Sort of uncharted territory.
I would probably do the same test at a couple of different excursion levels and sweep levels. Maybe low mid and high excursion and low mid and high output sweeps.
I know the mic won't care, neither will the driver or amplifier they just do what they are told. Sometimes there can be issues with a program taking control of the hardware which is outputting the signals and not allowing another program to share rights, I believe I have this taken care of though by now.
post #529 of 535
You wouldn't see the effect with a sine wave sweep I don't think since that is only a single frequency at a time. This shifting of response shape would not show up since only a single frequency is measured at a time. You would need a more complex signal with higher frequency content on top of a low frequency carrier that provides a lot of excursion. This could show up as distortion, weird noises at excursion, or possibly shifting, or ???? Seems like John J also mentioned something about this long ago.
Right Josh. I never said that a single sine wave clearly shows a fingerprint. I said it could be an issue during real playback where real signals have high frequency events riding on top of low frequency effects.
You can likely do it in software, but alternately a DCX-2496 or anything with the capability to sum two inputs will make it that much easier. Then you also have a simple way to vary either signal separately.
I might try lower like 10Hz to make it easier to observe the excursion. A bigger box or free air will make it easier to get more excursion with less total power. The other way it can be investigated is using air pressure to displace the motor like the DUMAX testing used to do.
Mind you all of this has been studied extensively by Klippel, but more so for wide range drivers, not subwoofers, where the only question is the degree of audibility, and less so happens. To be honest this is much easier to probe about and empirically verify vs. displaying in a graph. Effects from Cms and BL change will be much easier to see as these are generally symmetrical where it falls with both incursion and excursion, so the Rms measurement will be lower, and distortion will be representative of a symmetrically drooping transfer curve. In cases where Le significantly increases on incursion and decreases on excursion, the net level measured likely won't change, but distortion profile will.
While this is a form of IMD, we are more specifically interested in the distortion of the test tone during specific and relative excursion levels, not simply the interaction of multiple frequencies. So it's an excursion modulation test with specific constants.
post #530 of 535
Right...As you say I'm not sure of an easy way to actually capture this with one simple and presentable metric. I'm not so sure that a FR sweep will show much of anything. Could try a distortion sweep. What about dumping it into spectrum lab? I am going to try a few things and see what happens. It will be a couple of weeks though.
Dave or somebody else for that matter give it a shot if you have time I'd be interested to see what results there are if anything.
post #531 of 535
Hey, Silly question what should i expect from my replacement Q18...Scott said it is gonna be designed for my 5.5 cubic foot sealed box?
post #532 of 535
You should probably ask Scott but I would guess you will be getting the High QTS option which I was told is better for small sealed enclosures.
post #533 of 535
Bump...To continue on this topic.
I can easily run a measurement sweep with a steady state sine wave so that is no problem. I did a very quick measurement with a sealed woofer just as a sort of gauge but as Mark points out I'm not sure if this sort of thing can be easily presented on one graph or how to show it in a useful manner, what levels to use, signal, etc...So the question is how or what to do with this type of measurement, if anything at all. I'm open to experimentation to see if it can provide something worthwhile if anyone has ideas.
Attached is just a couple of basic results. A regular distortion plot with FR and also a capture of the woofer output into SL both with just a reqular sine sweep and the same sweep signal with a high level steady state 10Hz tone playing to provide a large amount of cone excursion. Should be pretty obvious which is which.
Attachment 241132
Attachment 241133
Attachment 241134
Attachment 241135
post #534 of 535
Hi Josh,
Thanks for the exercise.
Having a tough time with your SL scale. Is that 100dB in the middle of the color scale?
Bosso
post #535 of 535
Hi Josh,
Bosso
Sorry about that. I didn't put much time into getting the settings dialed in. I think it is 70-140dB overall scale. I haven't messed with SL in a long time, since learning how to calibrate the SPL level back when I received the dts10 kit I think.
