AVS › AVS Forum › Other Areas of Interest › Camcorders › Video edit software for audio adjustments
post #1 of 4
Can anyone recommend any software which would allow me to:
(1) Fix unsychronized video and audio throughout a movie (when spoken words do not correspond with mouth movements).
(2) "Level" the sound volume throughout a movie (to avoid loud music that blasts me off the couch).
(3) Increase the voice volume, and reduce the music volume (so music does not drown out the speech).
I want to make these "edits" to full length movies which I have copied onto my HDD from my purchased DVDs (mostly "MP4" and "AVI"). So far, I have only Standard Definition movies on my HDD, but I plan to copy my Blu-ray discs in the future.
I use a PC with a Core i7-950 CPU, 6GB of RAM memory, a 128GB SSD for my Windows 7 Home Premium 64-bit OS and programs, and 2TB HDDs for data and backups. My video card is only a ASUS GeForce ENGTS450.
post #2 of 4
I have finally solved my problem #1; i.e. how to synchronize audio and video for movies played on my TV from my computer HDD. I upgraded from my old "WD TV Live Media Player (Generation 1)" to the new "WD TV Live Streaming Media Player (Generation 3)". This new equipment includes a menu adjustment to synchronize audio and video, and it works to fix my movies which are unsynchronized!
I never could find a software program to fix this in my video files, but the new hardware is perfect for my setup. I do not have an A/V Receiver (or surround sound speaker system), but the "WD TV Live Streaming Media Player (Generation 3)" can be used between a computer and the Receiver (of course, this would not be needed if the audio/video sync adjustment is included with your A/V Receiver).
post #3 of 4
I am considering the same upgrade. I want to reduce the time between clips. If you put a collection of clips in a folder, select the folder and press play, what is the lag time between clips. My gen 1 players takes a few seconds.
I sent the same question to Western Digital and the odd answer was that I couldn't upgrade the firmware on the old one with the firmware of the new one.
post #4 of 4
Any NLE that has individual audio tracks and allows having multiple tracks can do what you want.
If A/V is sync'd when playing on a computer and is not sync'd when playing on a TV, then there is a problem with your setup. This is especially noticeable when audio and video take different paths, say you use a receiver or outboard scaler. My new BD player has a setting to set audio delay from 0 to 90 ms I believe.
  Back to Forum: Camcorders
