AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Amp Shopping for 2 L7 Kicker 10's
post #1 of 5
what amp is going to be the best to power 2 Kicker L7 10" subs,they are 2ohm Solobarics and rated at 600rms each
post #2 of 5
Budget?
And by 2 ohm, do you mean DVC with 2 ohm per coil? or dual 4 coils or single coil 2 ohm?
I use Sundown Audio. I have the SAZ 1500D. LOVE it.
Look for a 1500-2000 watt amp to drive those two subs.
post #3 of 5
they are 4ohm DVC...wired somehow from Kicker to be 2ohm overall
post #4 of 5
Budget?
post #5 of 5
Actually i talked to Aspen sound,and due to my limited airspace they said i need to go with 1 12" sub..so im just going to put these on craigslist and sell them.
Is there a good 4ohm sub that will handle 612RMS?
and what is better now that i have ported box for a single 12,and i also have an Obcon box for a sealed 12.
  Back to Forum: Car Audio, Video, and Nav
