@Jack,
I tested the EP950 on a different tv with the 2D test file "5-Sharpness & Overscan.mp4" - the tv is a Vizio E370VA. Just as on my Samsung tv, the top and right sides of the image were cut off. The tv was set to no overscan, and playing the same test file on a LG blu-ray player connected to the Vizio tv showed no cropping.
This proves that the the EP950 is indeed not centering the image properly in 2D mode - maybe in 3D mode too but I have no test file to try that. So side-by-side playback is a major problem with this player if you're intending to let the tv switch to 3D mode and leave the Micca in 2D mode, which would be the case if you're playing any sbs file in a framerate other than 23.976.
Can you please pass this to the firmware team and stress that this should be a priority at this point? This definitely should not be overlooked - I've played this test file now on 2 different blu-ray players and 3 different media players counting my Samsung tv's built-in player and the Micca is the only one that doesn't center the image correctly.
