First, they say all HDMI cables have ARC:
"All HDMI cables will support Audio Return Channel functionality when connected to Audio Return Channel-enabled devices. You can use your existing HDMI cables or choose a different cable type. (more)"
Then, they say ARC is new for HDMI 1.4:
"Audio Return Channel
The new specification adds an audio channel that will reduce the number of cables required to deliver audio upstream from a TV to an A/V receiver for processing and playback. In cases where a TV features an internal content source, such as a built-in tuner or DVD player, the Audio Return Channel allows the TV to send audio data upstream to the A/V receiver via the HDMI cable, eliminating the need for an extra cable."
________________________________
Talk about confusion. HDMI w/ARC, w/o ARC, w/LAN, w/o LAN, it sounds like Microsoft and the 7 Versions of Windows 7. They all look the same but are completely different. Supposedly there will be 5 official labels to tell them apart. Then of course, what are "A", "C", "D", & "E" connector types listed in their compliant list???
Great job. Can't wait for 4k confusion to hit.
Its already impossible to intelligently pick out a HDMI cable since there are no standard specs and everyone is pumping their product with anything from completely false claims to accurate ones - and 90% of the time no mention to the spec the cable meets such as 1.1 or 1.4.
Unfortunately, I need to buy a HDMI cable - I think I'll slit my wrists...
Tom
Tom
Nice explanation.
