Originally Posted by Joseph Clark
Hoya makes filters up to 82mm, but that still seems small for the front of the Epson 5010/6010. I've been meaning to buy a 77mm polarizing filter for my 3D camcorder anyway, and I was thinking of buying the filter set you're suggesting while I'm at it. What size do you use? I'll probably need to add an additional ND filter, too, since the torch mode on the 6010 would make the Epson far too bright for my 110" screen.
I don't think you'll need the ND filter at all. If you go with a filter to cut "green" then this alone will cause a 400 to 600 lumen loss (just a guess), so for 3D you're going to still need all those lumens that are left.
Don't worry too much about filter size. The filter does not have to be right against the lens -- the Epson's lens has an outer lip so if you have a lens cap from a previous projector or a plastic lid (say from a peanut butter jar) -- you can cut out the centre to fit your filter(s) in and slice the sides to allow the lid to expand enough to slide over the projector's lens lip. This Epson has a lens cover, but it is immediately in front of the lens so it won't interfere with your filter(s), which you can just leave in place. Your friend Ric should be able to help you calibrate the projector with filters in place. How you will do this for 3D through the glasses I don't know -- maybe rely on your eyes. For 2D you'll probably have the projector in economy mode (low lamp) so not too many lumens with filter in place -- shouldn't be a problem especially as the lamp ages.
I would start with one of the following filters -- FL-Day filter cuts green
http://www.hoyafilter.com/pdf/HOYACatalog.pdf
Try page 26 in this link.
http://www.schneiderkreuznach.com/pd...r_handbook.pdf
