AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › adding subwoofer to car...
post #1 of 8
I want to add subwoofer to my 2008 cobalt I have picked the following items and was wondering if I need anything else to assemble the subwoofer.
AMP:
Kenwood Kac-8105D 1000-Watt Class D Mono Amplifier w
Subwoofer:
Elemental designs e3.12 D2 Subwoofer
Wires:
DB Link PK4Z 4 Gauge Power Series Amplifier Installation Kit
Subwoofer box:
Atrend E12S B Box Series 12-Inch Single Hatchback Enclosures
post #2 of 8
Patience and a long weekend.
post #3 of 8
factory head unit? or aftermarket?
Do you own the subwoofer already?
Hey you live in Charleston! I go there a lot for work.
post #4 of 8
Yes, I go to school at Eastern!! I have the stock stereo, however, I plan on upgrading to a stereo with a sub preamp output. I don't have the subwoofer or anything yet.
post #5 of 8
What are you wanting to achieve?
Predominate music you listen to?
I ask because i would hate to recommend an ultra low distortion sub and you want to listen to rap and shake the neighborhood and the flip side I recommend a high output configuration and you want in car flat response for the low octaves of a string bass.
Bass in a car is the ultimate in ease. If you want a compromise, something that sounds good and yet moves air then I can recommend that as well.
Hatchback car?
post #6 of 8
I want nice clean bass that you can feel. However, I don't want the boomy sound I hear from "gangsters" since I don't listen to rap that much. I like artists like jack johnson and semisonic.
post #7 of 8
http://www.parts-express.com/pe/show...number=295-404
This is an amazing sub. Great output. Solid engineering. will play loud and low and clean.
post #8 of 8
Great! What box and and amp should I get for no more than $200? Thanks
  Back to Forum: Car Audio, Video, and Nav
