I'm now ready to make a purchase and thinking the w7000 is my choice since I need lens shift and think I would like to go back to DLP. I do have a few questions before I make the final decision.
1) When using the glasses, since they use the flash to sync, do they lose sync if you move your head to say.......look at someone next to you to talk, look down at your popcorn, or reach for the remote? Will the flash be detected by the glasses even if you look away?
2) Currently have an AX200......... so, I understand the black level is not a strong suit of the w7000, but how would it compare to the Panny?
3) A few here seem to have a problem with the iris clamping shut. With that being the case, might a case be made to favor buying a refurb for ~$150 less? Has the reason for this problem been found?
4) There's been little talk about a successor other than the 1070??, but that doesn't seem like a real replacement model, so would you say there is little reason to wait?
Thanks for any input. I am anxious to make my purchase, but wanted to make sure I will get what I think I'm getting.
