Featured Stories
Topics Discussed
- brandBenQ
- itemBenQ W7000 Home Projection System
- itemDLP Projector 2000 1080P
- categoryProjectors
Related Forum Threads
- Is this much spill light similar to that from a digital projector? Last post on 10/2/12 at 12:55pm in Screens
- BenQ W7000 Anamorphic projection Last post on 9/6/12 at 2:53am in 3D Displays
- Fan replacement in Benq W6000 Last post on 8/18/12 at 11:18pm in Digital Projectors - Under $3,000 USD MSRP
- Need some help..... Last post on 8/12/12 at 10:35pm in Digital Projectors - Under $3,000 USD MSRP
- Projector Screen Over a Wall-Mounted TV? What To Do For Speakers? Last post on 7/4/12 at 12:00am in General Home Theater & Media/Game Rooms
Related Articles
Projectors 101: AVS’ Favorites
Edited on 10/5/12
- Innovative and Interactive LCD Projectors for Large Rooms
Edited on 9/11/12Related Reviews
Official BenQ W7000 Owners Thread - Page 97
Gear mentioned in this thread:
- dukeav
- Trader Feedback: 0
- offline
- 80 Posts. Joined 1/2007
- Select All Posts By This User
That is the gray-scale adjustments, RGB gain is the same as RGB High end, and is basically like a contrast control for each color's gray-scale (not to be confused with the Gain controls in the Color Management System - CMS). The RGB Offset is the same as RGB Low. I would prefer if these MFR's would just call it Grayscale High and Grayscale LOW, would be less confusing since the gamut also has a gain setting (which is different).
You also need to calibrate the gamut. However, before doing any of this stuff, I recommend performing the below actions first:
Generally the first thing to do before calibrating is to set the GAMMA Preset to 2.2, setup the manual IRIS if needed (if your image is too bright or too dark overall), and then using the pluge and ramp patterns, get contrast and brightness setup correctly. Also make sure brilliant color is OFF.
Then start the gray-scale calibration, but take the 100 white IRE, 80 IRE, 60 IRE, and 40 IRE measurement first before trying to make corrective adjustments. I would then rely on the 60-80 IRE measurement for the first adjustments to gray-scale, get this flat as possible, then go to the 30-50 IRE and get that as flat as possible, and go back and forth until they are all pretty flat and accurate.
Now go to the gamut calibration and do the 75% patterns from the AVS Rec709 disk. Do the white point readings first though (100 IRE at least and 75 IRE). Next, spend time on getting each color within the proper point on the CIE chart by adjusting the settings inside Color Management (Hue, Gain, Saturation). I adjust HUE first, but the order does not really matter all that much. Then do saturation and gain until it is as accurate as possible. Then after you just calibrated the gamut, go back to the gray-scale patterns on the AVS disk and use the RGB High/Low to re-calibrate them, then after that, come back to the gamut again. You can play ping pong as long as you want depending on how accurate you want to get it.
My dE's were all under 2 when I was done I believe, one might have been near 3, but most at 2 or less.
Thanks for the tips.
One difference I find is that you are asking to set the contrast using the patterns instead of a target ftl reading. I had gone with guide and started with ftl of 22, but I think the image is too bright, so I'll try your way next.
Also In the first run I ended up with gamma around 2 with preset at 2.2. I then started with preset of of 2.4 and ended up around 2.2. I am guessing that it was due to the .8 gain screen I am using?
- Charles R
- Trader Feedback: +3
- offline
- 8,657 Posts. Joined 11/2000
I'm wondering if anyone else has seen this as if it's normal I won't bother getting a replacement. Installing a W7000 (for someone) I noticed when using all of the downward lens shift the image in the lower right hand corner (table mount) has a darker shade to it. It looks like a quarter circle (fairly large diameter on a 120 inch screen - 18"?) that is slightly darker. This is with the lens shift pointed straight down at 6 o' clock. I have moved the projector around to confirm it's not the screen and it appears to be simply a limitation of the lens/lens shift. If you move the image up via the lens shift (a couple of feet) it completely goes away. If you move the projector (itself) the dark area moves with it.
Funny thing is we had a couple of W6000s mounted in there for a month or so a long time ago using the same lens shift and I don't remember the issue... could have overlooked it but I doubt it. That's why I'm wondering if it's normal.
- Charles R
- offline
Thanks... but in this case I'm talking about a clear defect where the image isn't projected properly not mere chromatic aberration. Which I also tested by using hardly any lens shift and it was virtually the same.
Edited by Charles R - 1/27/13 at 11:30am
- Scott Tucker
- offline
- 2,440 Posts. Joined 8/2002
- coderguy
- PJ > TV
- offline
- 8,622 Posts. Joined 12/2006
Well as noted before, I don't leave my settings at an EXACT reference level calibration all the time, what I do is first make one calibration that has everything according to the meter (hence a "perfect" calibration), and store that in a preset. Then I adjust the second preset slightly by adding a bit of blue (not too much) and going slightly away from D65. I am not sure how exactly how much to go away from D65 for using blue to mediate skin tone error in the source, as it varies on every source, so at best it's voodoo but it still helps for my personal preferences. For my situation, I am also crushing the VL 17 sometimes because I adjust brightness and gamma a little darker than I should intentionally for some movies, but on DLP's with low native on/off, I prefer to crush blacks slightly on certain content and lose some detail in exchange for the perception of slightly better blacks. Just don't over do it.
The reason I prefer a slightly cooler than D65 image for one of my presets because a little extra blue in the gray-scale tends to help hide skin tone errors that exist in the source (cameras that used bad lighting when filming). A perfect reference level D65 calibration does look better on reference level content, but if you average films across all viewing content on how the skin tones look, a tiny bit cooler image on average can help. I have become so sensitive to the unwanted color that exists in films and the bad skin tones, that I try to negate this a little. The "director's intent" in some films is truly awful now-a-days, these guys took one too many hits of an illegal substance.
Edited by coderguy - 1/29/13 at 2:22am
- coderguy
- PJ > TV
- offline
I will PM them to you.
Edit:
I need to A/B the Universe series and the game X3: Albion Prelude/ Terran conflict between the VS and the Benq again, this game has tremendously rich black scenes. It's kind of weird but the Benq seems to have a better intrascene ramp than some projectors even though it has such low On/Off. When I put enough stars on the screen, the blacks seem to be improving faster than the Viewsonic, the JVC though still creams these two in blacks.
Edited by coderguy - 1/27/13 at 10:13pm
- bcarithers
- Super HD
- offline
- 140 Posts. Joined 1/2008
Wanted some screen advice for the 7000...I have a chance to get a good deal on an elite Cinegray 106" screen. I know it tends to make the image a bit darker but since the BenQ is so bright, would it be a good combo?
Room is 95% light controlled basement. Throw will be about 15 ft and seating distance is about 10ft.
What do most of you BenQ owners use? Gray or white screens? What is a good gain amount for such a bright projector?
- coderguy
- PJ > TV
- offline
It will never be too bright, as I said before you can use a 2.0 gain 60" screen and it still isn't too bright, the IRIS can be clamped down completely.
- bcarithers
- Super HD
- offline
- coderguy
- PJ > TV
- offline
- bcarithers
- Super HD
- offline
A forum member is selling a 106inch Cinegray for a great deal so I would like to go with that unless the image would be terrible...
Anyone else using the BenQ with a low gain screen??
- coderguy
- PJ > TV
- offline
- dukeav
- offline
Well...throwing from 15ft away what kind of brightness do you think I can get with the Cinegray (0.8 gain) The Cinewhite is only 1.1 so I was not sure how big a difference that would make.
I use it with 100" Black Diamond 0.8 gain screen from about 14.5 feet and its more than enough bright even on low lamp.
Wearing glasses, cleaning, dust, scratches on the lens, batteries, tints etc etc.
The attention is drawn away from the sound and the width of the screen somewhat dimishes, a more narrow experience develops.
And as good as the W7000 is, 3D still looks a bit fake compared to 2D.
This became apparent after rewatching a lot of my 3D movies in 2D again, I was like WOW, I think I prefer 2D. LOL
Glasses free 3D, that I could give a go.
Farewell W7000, hello JVC X30 blacks.
- coderguy
- PJ > TV
- offline
- malichai
- offline
- 205 Posts. Joined 12/2002
- Charles R
- offline
Per se I don't believe there is any difference... the same model under difference name during its production run. Specs and performance identical... whether there are any manufacturing differences who knows. I think it's safe to say one isn't inherently better than the other.
I would never buy anything but an HP screen with this projector, it's just screaming for it with the center-based offset + the manual IRIS which lets you control brightness. Of course if someone wants dimmer 3D and to buy new lamps sooner, then that's their right.
Yea, this is only a good idea if you are going to manually control the iris (or use a very large screen). Otherwise it can end up too bright if you use the DI mode. I tried my 106" HP screen with my W6k (which isn't as bright as the W7k) and it was crazy bright in a fully darkened room.
- coderguy
- PJ > TV
- offline
Of course this is more important for us heavy projector users to curtail losing too many lumens too fast in the first 500-1000 hours.
- Charles R
- offline
I agree. I installed a few W6000s and just recently a W7000 and I was looking for ways to make them less bright. Throw in the less than stellar black and a dim screen is a very good choice for many.
This is assuming you want to use the DI though. If like me you find the DI distracting and can see it pumping away and will be shutting it off anyway, you can tailor the brightness on the 6000/7000 by adjusting the iris in the service menu as Coder has mentioned. I still need to track down that great post by Coderguy on how exactly to tweak the iris as I still have not messed with this, but plan to next time I watch 2d on the 7000 (which is not much).
- Charles R
- offline
Not really. Even with it turned off I had to go into the service menu to reduce the light output... dramatically. Sure in some living rooms the brighter the better... in other rooms that isn't the case therefore the brightest screen available isn't required... there are many other factors. It's not like it's going to get too dark later on... even if it did I'll be giving up a little to gain a little or more... I noticed the image noise (greatly) when the W6000 was too bright. With the W7000 I had to go down to 6 (from the default of 13) to tame the image. Plenty left to recover as the lamp dims.
Far too many room configurations and preferences to make a blanket statement is what I'm saying... saying by default at some point the projector will get too dim and as such should override everything else.
Edited by Charles R - 1/30/13 at 10:26am
Not really. Even with it turned off I had to go into the service menu to reduce the light output... dramatically. Sure in some living rooms the brighter the better... in the rooms that isn't the case and if the screen can help lower the black level I'm all for it. It's not like it's going to get too dark later on... even if it did I'll be giving up a little to gain a little or more... I noticed the image noise (greatly) when the W6000 was too bright. With the W7000 I had to go down to 6 (from the default of 13) to tame the image. Plenty left to recover as the lamp dims.
My point was that a dim screen would be a good choice if you choose to use the DI since you cant use it as a manual iris at that point to tame brightness (right?). If you are going to shut off the DI anyway though assuming you find it distracting, you could go with either a dim or high gain screen since you can now adjust the iris in the service menu.
I agree with you that the projector is VERY bright and too bright in my particular setup right now as a matter of fact. I am in a cave of a room with a HP screen on top of it and the brightness is a bit uncomfortable in its current default iris setting for 2d (love all the brightness for 3d though). Glad we can go into the service menu and lower it by adjusting the iris, otherwise I would need to find some sort of ND filter for what little 2d I watch.
- Charles R
- offline
I don't disagree with the theory. My only point (badly made) is I don't feel in all cases the projector will become too dark... hence you may not need to the brightest screen with it and others may work as well or better. I was only referencing the post... x screen is the only one I would use/purchase...
Gotcha, sorry my bad!
I totally agree with you there. I think it depends on the intended use as well. If someone is going to mainly be watching 2d, I think I would actually lean toward a low gain screen in light (no pun intended) of how bright this projector is. If you are going to mainly be watching 3d though, I would definitely lean toward a HP screen (or some sort of high gain screen) if it will work in the setup (if not, there are still good options for a screen of course). As you mention though, tons of variables and there are many options for screens depending on the particular set of circumstances.- Official BenQ W7000 Owners Thread
Recent Discussions
- › Official Sony VPL-VW95ES Owners Thread 19 seconds ago
- › The New PQ Tier thread for Blu-Ray - Discussion 41 seconds ago
- › panasonic calibration questions/issues... 42s60 1 minute ago
- › Does your Samsung plasma suffer from horizontal line bleed? 1 minute ago
- › POPCORN HOUR A-400 is coming soon 1 minute ago
- › The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] 1 minute ago
- › switching from unraid to whs2011 =flexraid 2 minutes ago
- › Lens shift on the Sony HW50ES compared to the Epson 5020 and the... 3 minutes ago
- › Official Sharp LC-90LE745U Discussion Thread [No Price Talk] ... 3 minutes ago
- › #### The ULTIMATE Bass Demo Disc #### 3 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
