I've made an extensive amount of posts recently over at [H]ard|Forum about the iSymphony LC32iF90 but, I wanted to share a condensed version here. Please make sure to add it to the avoid at all cost list.
I recently picked this TV up from Conn's for $279.99. Unfortunately, once I hooked it up to multiple PCs, I found out the native resolution is 1280x720p. This is in direct conflict with the box and specifications that the native resolution is 1920x1080p. Yes, it's true that you can tell Windows or the video card driver to change the resolution to 1920x1080p. However, you shouldn't have to do so and, any resolution over 1280x720p will force the TV to overscan which will cut off a great deal of the picture including your entire taskbar. The only way to correct the overscan is to use your graphics card's underscan feature which will result in it running at a lower resolution than 1920x1080p or whatever you set it to. There is no option in the TV settings to switch to a 1:1 pixel mapping as you can only change the TV to "wide (16:9) or "normal" (4:3).
In addition to this, text on the PC was multicoloured in any progressive scan resolution higher than 1280x720p. All interlaced resolutions above 1280x720p removed the multicoloured text issue but, they created a flicker when you would open/close programs or use a scroll bar. This TV also failed 4:4:4 chroma colour tests. It's not advertised as having 4:4:4 chroma but, it is crucial that a display being used as a PC monitor is able to run in the 4:4:4 chroma profile.
All of these problems existed over VGA to VGA (this will not go higher than 1280x720p), DVI to VGA, DVI to HDMI, and HDMI to HDMI signals. I tired multiple solutions and researched this issue extensively over the short period that I owned this TV. This is not an issue with the video card driver nor is it an issue with the monitor driver Windows installs as I tried multiple custom drivers and edits to them. It is an issue with the EDID which is contained inside the TV's hardware which broadcasts all the hardware information to your operating system. It states the following:
Monitor Asset Manager Report, generated 2/2/2012
Copyright (c) 1995-2011, EnTech Taiwan.
Monitor #1 [Real-time 0x0041]
Model name............... MTC26T42
Manufacturer............. Mitac
Plug and Play ID......... MTC0B01
Serial number............ 1001
Manufacture date......... 2008, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 700 x 390 mm (31.5 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.652 - Ry 0.333
Green chromaticity....... Gx 0.275 - Gy 0.595
Blue chromaticity........ Bx 0.143 - By 0.063
White point (default).... Wx 0.285 - Wy 0.293
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 14-91kHz
Vertical scan range...... 22-80Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.030 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #3....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #4....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #5....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 205MHz
Report information
Date generated........... 2/2/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0041
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,36,83,01,0B,E9,03,00,00,01,12,01,03, 80,46,27,78,0A,19,90,A7,55,46,98,24,
10,49,4B,01,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,C4,8E,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, C4,8E,21,00,00,9E,00,00,00,FC,00,4D,
54,43,32,36,54,34,32,0A,20,20,20,20,00,00,00,FD,00,16,50,0E, 5B,10,00,0A,20,20,20,20,20,20,01,9A,
02,03,22,72,4D,03,84,05,07,10,12,93,14,16,1F,20,21,22,23,09, 7F,07,83,01,00,00,67,03,0C,00,10,00,
98,29,8F,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18, 01,1D,00,BC,52,D0,1E,20,B8,28,55,40,
C4,8E,21,00,00,1E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E, 21,00,00,9E,8C,0A,D0,90,20,40,31,20,
0C,40,55,00,C4,8E,21,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E, 96,00,C4,8E,21,00,00,18,00,00,00,37
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI000 18.PCI0001C
00000000 = 01048086.20900006.06000009.00000000.00000000.00000000.000000 00.00000000
00000010 = 01168086.00900407.03000009.00000000.F7800004.00000000.E00000 0C.00000000
000000B0 = 1C3A8086.00100006.07800004.00800000.F7F0A004.00000000.000000 00.00000000
000000D0 = 1C2D8086.02900006.0C032004.00000000.F7F08000.00000000.000000 00.00000000
000000D8 = 1C208086.00100006.04030004.00000010.F7F00004.00000000.000000 00.00000000
000000E0 = 1C108086.00100007.060400B4.00810010.00000000.00000000.000202 00.0000E0E0
000000E8 = 1C268086.02900006.0C032004.00000000.F7F07000.00000000.000000 00.00000000
000000F8 = 1C498086.02100007.06010004.00800000.00000000.00000000.000000 00.00000000
000000FA = 1C038086.02B00007.01060104.00000000.0000F0B1.0000F0A1.0000F0 91.0000F081
000000FB = 1C228086.02800003.0C050004.00000000.F7F05004.00000000.000000 00.00000000
00000200 = 816810EC.00100407.02000006.00000010.0000E001.00000000.F00040 0C.00000000
00000300 = 08858086.00100406.02800067.00000010.F7E00004.00000000.000000 00.00000000
00000600 = 01941033.00100406.0C033004.00000010.F7C00004.00000000.000000 00.00000000
01040000 = 00FFFFFF.FFFFFF00.3683010B.E9030000.01120103.80462778.0A1990 A7.55469824
00000020 = 10494B01.08000101.01010101.01010101.01010101.0101011D.007251 D0.1E206E28
00000040 = 5500C48E.2100001E.011D8018.711C1620.582C2500.C48E2100.009E00 00.00FC004D
00000060 = 54433236.5434320A.20202020.000000FD.0016500E.5B10000A.202020 20.2020019A
01040100 = 02032272.4D038405.07101293.14161F20.21222309.7F078301.000067 03.0C001000
00000020 = 98298F0A.D08A20E0.2D10103E.9600C48E.21000018.011D00BC.52D01E 20.B8285540
00000040 = C48E2100.001E011D.80D0721C.1620102C.2580C48E.2100009E.8C0AD0 90.20403120
00000060 = 0C405500.C48E2100.00188C0A.D08A20E0.2D10103E.9600C48E.210000 18.00000037
I called the manufacturer after I called their parent company to get their number (800-710-7740) as their technical support line sends you directly to voicemail. I was hoping they could clear this matter up or provide a possible solution. Instead I was told that there is nothing they could do because, it "wasn't their TV". They didn't even understand the importance of the native resolution until after I explained it in detail. Even then I was told there was nothing that they could do because, they "didn't manufacture it". Once I told them that other TVs sold with a native resolution on 1920x1080p do not have this problem, I was told I couldn't "compare TVs to one another as they have different components". My response was that yes you could compare TVs as that is how comparative shopping works. Even if you ignored competitive shopping, there is still the issue that this TV is being sold as having a native resolution of 1920x1080p. When something is advertised as having a native resolution of 1920x1080p it has to actually have that as the native resolution on all of its input channels. This is an industry standard and all manufacturers are bound to it.
Even if you do not plan on using this TV for computer use, I advise you to not purchase it as you will not be getting what you payed for since the native resolution is 1280x720p and it is being falsely marketed as 1920x1080p by iSymphony. In addition to that the manufacturer refused to take any responsibility for the issue so they are far from reputable or trustworthy.
I would also like to point out that the TV is incredibly slow to respond to the remote control. Switching to a different input is also very slow and, you have to sit through an incredibly bright and painful "loading screen" that is white and then a very pale lavender every time you switch to a different input. To stress how bright this screen is, picture your contrast, brightness, and the backlight as high as they can possibly go. After the TV has successfully switched to another input, you can watch it "re-process" the image several times as the colour, contrast, and brightness will all change considerably multiple times. There is no way to turn this processing or any other processing off except for the cable clear one which does nothing. There is also no way to adjust the hue (R/G/B) which is the white balance and the TV's menu is incredibly limited as it is missing basic functions like a backlight adjustment. There is also no way to adjust sharpness over a VGA signal and that signal is in dire need of having it sharpness reduced.
I know the reviews here at Amazon speak very highly of this TV but, I suspect they haven't figured out that it is actually a 1280x720p native resolution TV. The one I purchased also had light bleed in the corners, cross talk during a viewing angle shift, and some minor clouding. The image also "washed out" very rapidly from a minor viewing angle shift and even looking at the TV in the center would leave the sides a bit "washed out". The colours and back levels were actually fairly nice but, you had to have the black levels a little gray or there is an excessive amount of "black crush" that will take place. However, the gamma is also incredibly high and, there is no way to get it at the correct level without introducing "black crush" and losing a lot of the colours on the lower end of the spectrum.
Again, I seriously urge anyone thinking of picking this set up to strongly reconsider doing so especially at it's typical price point of $349.99 as there are much higher quality TVs that are actually what the claim they are in this price range. I only payed $279.99 for it and, it was incredibly sub-par for even that price. I had high hopes for this TV based on the reviews (at another site) and specifications but sadly, it failed to meet any of those.
Conn's however made the return hassle free and even tried to find a comparable model or something that they could adjust the price on. Unfortunately there just wasn't anything available at this time. They may have "lost the sale" but, I would certainly shop with them again.
I decided to take pictures of the failed 4:4:4 tests and of a pitch black scene of video playback. I didn't take images of the multi coloured text because you can all picture what that looks like even if you have never seen it. Please forgive the crappy quality as the camera just refused to focus despite being in macro mode. You may not be able to see the light bleed image unless you shift your viewing angle and/or mess with your brightness/contrast. Just let me know if there is an issue viewing it.
4:4:4 test (1920x1080p) DVI cable (male to male) to HDMI adapter (female DVI to male HDMI)
4:4:4 test (1920x1080i) DVI cable (male to male) to HDMI adapter (female DVI to male HDMI)
The light bleed. Please note the light I see isn't blue (like it was on the camera) but, this was the best I could mimic it. I also want to point out that the area on the bottom left isn't really there. That's a result of the screen "wash out" from the angle shift. Likewise, a most of the lower right corner is also washout and not actually light bleed. If you move your eye level to either of those corners or their vertical sides, that area will darken. of course when you do this the middle of the screen will lighten (which is why I think this might be cross talk). The image also didn't show the light bleed in the top left corner but, it's almost identical to the light bleed in the top right corner. Speaking of the top right corner, it's a bit more "intense" than the picture would lead you to believe. This image was also taken with the brightness turned down much lower than it normally would be so that the bleed could be seen clearly without the actual movie "darkness" affecting it.
