AVS › AVS Forum › Audio › Audio theory, Setup and Chat › HDMI Noise and Signal Interfernce for HTPC
post #1 of 13
Hi Guys this is my first on AVS [ please be nice ]
I recently built a HTPC for my parents based on
AMD A4 3400 Dual Core Fusion CPU
ASUS F1A75-I Deluxe Mini-ITX Motherboard
Gigabyte MIB T3140 Black Mini ITX Case
SONY 32" FullHD TV
- HTPC works fine on the TV connected via HDMI
- But, when i watch cable-TV which works via 3channel (red, blue, Yellow cables) there is heavy noise and some signal distortion
- This distortion when watching cable is present even when the HTPC is turned off (but all cables plugged in)
- The only way to eliminate this is to either physically unplug the HDMI cable or Physically unplug the Power cable from behind the HTPC
- I have tried physically separating these cables as far apart as possible when plugged in , but this does not solve this problem either
Any help would be good
Thanks guys
post #2 of 13
Looks like a grounding problem.
Why are you using composite video for your cable box? Does it not have an HDMI output?
post #3 of 13
Coaxial Cable for the Cable-Box from the street and then 3channel ( older tech ) into the TV
post #4 of 13
I realize that is what you are using. I am asking if it doesn't also have an HDMI output that you can use. That signal is digital and will be immune to the distortion you are seeing.
post #5 of 13
Even though it's a digital connection, it can still be a factor and confounder for ground loop problems as it's an electrical connection.
I'll wager the culprit is your cable co coax feed. Specifically, the feedthru coupler at the building entry isn't properly earthed.
post #6 of 13
I didn't say otherwise. I am advising him to move away from composite video for his cable box that is getting impacted by the ground loop. If we convert that connection to digital, we have a shot at solving his problem and improving his video quality immensely.
post #7 of 13
And I was trying to address a possible root-cause for his ground loop problem. Not work around it. As a trouble-shooting aid, you can (temporarily) earth the coax shield entering the STB or HTPC. If this knocks it down or eliminates it, you know what it is and how to fix it properly.
In 90% of the ground-loop problems I've seen in a system that involves a cable company connection, the problem is what I noted. I've seen >60V on cable co coax shields. In addition to a horrendous ground loop problem, it's also a big safety problem. It's why by code, the building feedthu coupler must be properly earthed. Often they are loose, missing or corroded and gunked up with decades of paint.
He said he's using '3 channel' analog which would presumably be component, not composite, and HDMI may not be so 'immensely' better PQ than component. Both done properly should yield about the same results. If the root-cause of the ground loop or ground potential is eliminated, then all the connections should be more robust.
post #8 of 13
Hi Guys,
thanks for your replies
I just checked the cable box.. there's no HDMI out on it,
Also new info, there is cable box which belonged to an other cable provider that uses HDMI to the TV ( which has been moved to another room )
So the HDMI-Wired-Cable box and the Coax-Cable-Box and the TV used to work well without any interference between each other (before the HTPC came along)
so this looks like a problem created by my HTPC which works well by itself, but causes interference to the other 2 cable boxes
i must say tho that the coax-cable-box wiring looks pretty shoddy with exposed leads on the plug ( but for some reason works with the other hdmi-cable-box )
Thanks again
post #9 of 13
Your HTPC is likely to be a confounder as it has a safety ground connection in the power cord. Three wire power cord vs the two wire cord the STB and TV likely has. Yes?
Do you have a volt meter and know how to use it safely? Can you test things visually with the cable co coax feed disconnected and removed as a variable? (Use STB menus/OSDs)
post #10 of 13
It is common for these problems to pop up when you add one more gear. If you swap the cable boxes and use the one with HDMI next to the TV with HTPC, does the problem go away?
post #11 of 13
++ disconnecting the Coax input and using the OSD from the cable box. Does the noise go way with the coax disconnected but the OSD displayed? Also if you have a multimeter with an AC Voltage Autorange you can put one lead to ground on the outlet and the other lead on the hex connector on the coaxial and see if you have voltage going across. This is assuming that your outlets are wired correctly.
BTW Dlarsen, the OP did say he is using component. Yellow for video and the R/W for the stereo channels. He didn't list S/PDIF or TOSLink as a connection so:
1. I doubt he is getting anything above SD out of the cable box
2. It doesn't sound like component
OP, Do you have ANY other connections from the cable box to the TV other than the three lead cable?
post #12 of 13
He said '3 channel' more than once and never mentioned audio or stereo in this connection. My HD STB has component video and I believe that most HD STBs have component vid out. Yes, the sun has set there though.
post #13 of 13
I know, just thinking that when OP posted: But, when i watch cable-TV which works via 3channel (red, blue, Yellow cables) there is heavy noise and some signal distortion
May be that he meant red/black/yellow. I dunno. But without any other mention of any other kind of cable I have to think it is composite. Yellow being video, and the other two for stereo.
Any ways clarification has been asked for. Just need to wait.
