Looking to up grade my Epson 8500ub, and would appreciate suggestions concerning which projector (under $10000K) would produce the sharpness of a DLP with the deep solid blacks of a LCD/LCOS pj. It may not exist. Note, I have no need for 3D.
AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › DLP sharp with LCD/LCOS blacks
Featured Stories
AVS Top Picks
post #2 of 84
12/23/11 at 8:47am
This question seems entirely dependent on your setup. Light control, screen size etc. without those details I would say look at the JVC RS55 the new e-shift should help with the "DLP sharpness" especially if you are or would like to sit closer to your screen. Then you also get the best black level as well...
- cdnscg
- Trader Feedback: 0
- offline
- 761 Posts. Joined 2/2004
- Select All Posts By This User
Fair enough. Screen is 120" Grandview tab tensioned. Room is well enclosed, however, walls are light grey with a white ceiling. I sit 14-16ft from the screen with the pj directly overhead.
post #4 of 84
12/23/11 at 8:57am
- cdnscg
- offline
Great, how do the blacks compare with Epson which I fine great in dark scenes, but the image a little washed out in brighter, no doubt due to the light colors of my room.
post #6 of 84
12/23/11 at 9:19am
- rboster
- Trader Feedback: +11
- AVS Moderator
- offline
- 17,432 Posts. Joined 7/2000
If memory serves (and I could be wrong), he owned a Benq 8750 (which I also owned at one point). If it were me, I'd want to compare JVC's new line up to the Planar 8150 or similar value/performance DLP. The Planar out performes the Benq is most area's, including sharpness and black levels. I think Kris Deering has made the switch from the Planar to either a Sony or JVC...I would look up his comments. If he hasn't made the switch, I think he's at least reviewed for Home Theater Magazine the new units and would be able to comment on a comparison to the Planar (which I think he had for his personal projector)
post #7 of 84
12/23/11 at 9:36am
- Kris Deering
- Trader Feedback: +8
- Avid HD Watcher
- offline
- 5,997 Posts. Joined 10/2002
post #8 of 84
12/23/11 at 9:59am
Can you compare the Planar to your RS35 and RS45 if you have seen one?
At some point I will look to upgrade from my RS10. I am happy with the blacks but would like to improve sharpness, motion and get that "dlp pop" while keeping case noise in the low 20's for db.
post #9 of 84
12/23/11 at 10:17am
- WTS
- offline
- 1,767 Posts. Joined 11/2002
Hi Kris,
I'd like to know if you plan on reviewing the new Benq W7000 as I'd like to know how it compares to the LS5. I saw the LS5 and thought it had a great picture with the exception of the RBE. I understand the W7000 has a faster CW so that should cure the RBE problem but I'm wondering if the blacks will be up to the LS5s level.
- cdnscg
- offline
Have you owned a lcd/lcos pj, and if so, can you advise if the blacks are comparable.
Also, I read awhile back that dlp had issued with a rainbow effect. Was that just for tv's? Is there a downside to up to date dlp pj technology?
post #11 of 84
12/23/11 at 12:25pm
- danieledmunds
- Habitual Gambler
- offline
- 899 Posts. Joined 8/2006
I previously had the JVC RS1, then moved to a Sharp Z15000, then an Infocus IN83. I hate auto irises so the IN83 not having one was never an issue. The black levels on the Sharp were OK but the IN83 is better, much closer to LCOS. I would still say the JVC probably had a slight edge but it was minimal.
Of course the native contrast has progressed for LCOS considerably since the RS1. I don't think the same can be said for DLP Darkchip4 native contrast. If you took out the dynamic iris out of the equation, I wonder how much real difference in native contrast there would be between an IN83, Marantz 11S2, Sim2 Nero and the Vango?
- cdnscg
- offline
post #13 of 84
12/23/11 at 12:47pm
- stumlad
- Trader Feedback: +4
- offline
- 2,399 Posts. Joined 11/2006
What other display types have a similar "pop" that DLP has ? I'm curious because I've never seen a high end home theater DLP, so I have nothing to compare to. Do plasmas have a similar "pop"... ?
I'm also confused what the term means... Someone mentioned that the OLED Hmz-t1 does not have the same "pop" that his DLP has. It's probably impossible to measure, but the black levels on that thing are better than the JVCs... and as far as I know, OLED has identical ANSI as it does on/off...
post #14 of 84
12/23/11 at 1:09pm
For me, the "pop" means an extra sense of 3d or depth to the image. I saw a Planar 8150 very briefly a few years ago and it seemed to have that, but I really did not have the chance to test it much.
post #15 of 84
12/23/11 at 1:56pm
- Seegs108
- Dylan Seeger
- offline
- 1,412 Posts. Joined 7/2007
I own a Planar PD8150. I switched to this from a JVC RS20. To be honest, the Planar does a very respectable job on blacks. The dynamic iris algorithm is one of the best in the business. I used to own a Epson 6500UB and I can say that the Planar's implementation is vastly superior. You wouldn't know the Planar was using a DI unless you were intentionally looking for it. It's never once stood out during a movie even when I was expecting it to, like during a dark to bright scene change. It does it's job as subtle as possible but yields great results at the same time. The image is much more crisp than my RS20 ever was, but I'm sure JVC's newer models fair better.
post #16 of 84
12/23/11 at 2:48pm
- coderguy
- PJ > TV
- offline
- 8,688 Posts. Joined 12/2006
Hey Guys,
As long as you get a JVC RS-45 with good convergence (and from the sounds of other peoples experiences, you will), it will be as sharp as many DLP's, even sharper than some of the cheaper DLP's.
I do own a JVC RS-45 right now. In the past I have owned the Mitsubishi hd1000u, hc3800, hc4000 (all DLP's). I now own a Viewsonic Pro8200 DLP. So I have owned 4 DLP's. I have seen a Benq w6000 briefly and a bunch of other DLP's. I've also owned a Sony vw70 LCOS, Epson 8500ub, Sanyo z5, and a Sanyo z4000. I know I am forgetting one or two, but those are the main ones.
Out of that entire list, I would only rate (2) projectors a tiny bit sharper over the JVC RS-45, that would be the Mits hc4000 (barely barely barely) and the Benq w6000 (barely), and they are only a tad sharper at best. The JVC is so sharp that these other two projectors will have very little advantage even in HTPC sharpness over the JVC, if even any.
The JVC is ultra-sharp.
See my post here:
http://www.avsforum.com/avs-vb/showt...8#post21387038
Stand back about 2-4 feet from your monitor when looking at the above image, and that should be about how text will appear on HTPC on the JVC. Even with the above post, I couldn't capture its sharpness 100% perfectly due to my camera's limitations, but it is unbelievably sharp for an LCOS unit.
DLP vs. LCOS
It just depends what you are watching to what will be favored. DLP's are still a bit better in some games because of smoother panning and less lag, but overall the JVC is a good gaming machine (lamps are expensive though), but I still recommend a cheap DLP for gaming and the JVC for everything else. Sometimes bright scenes look better on the JVC even over a DLP, it depends on the lighting though. For poorer sources playing bright movies (think Action movies on Netflix), the DLP will usually look better, other than that the JVC RS-45 wins.
As far as black levels on these newer DLP's, they are not that great. The LS-5 and Planar 8150 and Infocus sp8602 are the only three DLP's I know of in this price range right now with decent black levels. They will not touch the JVC's black levels though.
You can't go wrong with the JVC RS-45 really, but owning 2 projectors isn't a bad idea either since cheap DLP's tend to have cheap lamps and you won't feel guilty for leaving it on all the time.
The JVC RS-45 has at least 10x the native contrast of even the high-end DLP's Native, that doesn't equate to 10x the advantage, but it is significant none-the-less. When you watch a movie like Star Wars or Harry Potter on the JVC, it is a breath-taking experience, it's not like a small improvement, it's huge even over the Epson LCD's.
See my post here:
DLP vs. LCOS
post #17 of 84
12/23/11 at 4:51pm
Originally Posted by coderguy
Hey Guys,
See my post here:
DLP vs. LCOS
Hey Guys,
See my post here:
DLP vs. LCOS
Very interesting, thanks for the perspective guys. I will need to see these live.
post #18 of 84
12/23/11 at 5:47pm
- Kris Deering
- Avid HD Watcher
- offline
The RS35 has better blacks and is sharper than the Planar 8150 I owned. The Planar may have been a tad brighter though. Planar did a good job with their dynamic iris system, but it does have some issues with certain material. I find the Sony dynamic system to be better in that respect. The Planar showed less banding in ramps than the JVC does, but with normal viewing material they are about the same. At the end of the day I would take the RS35 I have over the Planar, but they are both great projectors.
I have seen one RS45 for an afternoon. It was extremely sharp, which was a surprise. I owned a RS40 for a bit and the 45 was considerably sharper than it was. But focus uniformity across the screen wasn't on par with my 35, and convergence wasn't quite as good either. Black uniformity was a bit better on the 35 but on/off CR measured a bit better on the 45, which was also considerably brighter. ANSI measured quite a bit more on the 35, but neither PJ seemed to outdo the other in blacks or contrast with program material (we were running both brightness matched and switching the image rapidly with different material). From what I saw for that limited time the RS45 presents an amazing performance level for the money.
- cdnscg
- offline
Hey Guys,
See my post here:
DLP vs. LCOS
Hey Guys,
See my post here:
DLP vs. LCOS
Thanks for this, and all the members input. It really helps. To summarize, the JVC will give you a sharp picture, as close to an upper DLP, with solid blacks. The blacks are as good as an Epson, but with a much sharper picture.
My main interest are movies. I don't watch tv or play games on my pj. If its a huge improvement over the 8500ub Epson in sharpness and with equal blacks, it sounds great.
post #20 of 84
12/23/11 at 7:46pm
- WTS
- offline
- cdnscg
- offline
post #22 of 84
12/23/11 at 8:09pm
- Joesyah
- offline
- 2,173 Posts. Joined 9/2009
I would rate the sharpness on a scale of 1 to 10. 10 being the sharpest I've experienced. The RS45 is an 8.5.
Equal blacks? No it will well outpace the 8500 in contrast and black levels..no contest there.
Remember the RS45 is comparable in this area to an RS35/25.
A JVC HD250/ RS15/RS10 has better contrast and deeper blacks than the 8500.
- cdnscg
- offline
From which pj is the sharpest you've experienced?
post #24 of 84
12/23/11 at 8:32pm
- Joesyah
- offline
This is my first LCOS. All of my previous projectors were DLP. The Runco Q750 is the sharpest I've seen. Followed by the Infocus SP8602 and Benq W6000.
The JVC is sharp enough not to be concerned. For what it loses to the others in sharpness, it makes up for in contrast.
post #25 of 84
12/24/11 at 7:18am
- coderguy
- PJ > TV
- offline
@Others
The blacks on the RS-45 are far far better than the Epson 8500ub/8700ub/5010, there is no comparison to be honest.
The Epson blacks look flat in comparison, Harry Potter and similar movies look all 3Dish in the dark scenes on the JVC because the contrast adds so much depth. On other projectors, these types of movies look flat. On the JVC the scenes appear to have a rich dark looking sparkle to them, almost like looking at the stars at night.
A DLP projector has a harsher pixel grid, so it may appear sharper in a few scenes because the pixel fill is more visible, but it's really not any sharper for video. I agree about an 8.0 to 8.5 is how I'd rate the sharpness on the RS-45, and I've seen 30+ different projectors.
The RS-45 is the sharpest NON-DLP I have ever seen. I am not just saying that either, you do have to get it mounted right to get the maximum sharpness (not too much lens shift), and there is a 15 minute warmup time or so for convergence to zone in, but overall the projector runs away from the other NON-DLP's in sharpness that I've seen.
I am about the pickiest person in these forums when it comes to sharpness, and this is the first projector I've ever been satisfied with on sharpness that wasn't a DLP.
The contrast is amazing, and I absolutely think this is the best projector ever made under $3,500 for 2D movies, period.
- cdnscg
- offline
@Others
@Others
Thanks again to all. Could you explain what the right mounting position would be for max. sharpness. My present pj is mounted on a 7-8ft ceiling 14-16ft from the 120" screen, directed to the middle. By lens shift, are you referring to when a pj is not centered, and therefore must adjust to either side to secure the correct picture form. Is the ceiling mount I have in line with a right mounting position?
post #27 of 84
12/24/11 at 8:03am
- coderguy
- PJ > TV
- offline
You will be fine with a ceiling mount in that position, that is very close to the sweet spot generally. Even if you weren't at the sweet spot, the added CA error is very minor and not visible in normal viewing.
There are different sweet spots to different units depending, but you won't be able to see any CA error from your seating position anyhow. I was just saying that in reference that the convergence is so nearly perfect on my unit that the added error can be seen with different mounting positions if you put your nose to the screen, but that's about it.
On most NON-DLP projectors the convergence is off enough to where when you use LENS SHIFT, it isn't that noticeable even when you are kind of closeup (it is still noticeable,but I mean it's not a huge difference since most projectors start with more error), but the RS-45 is just so perfect at its sweet spot is what I meant.
post #28 of 84
12/24/11 at 8:39am
post #29 of 84
12/24/11 at 9:15am
- Joesyah
- offline
post #30 of 84
12/24/11 at 9:44am
- coderguy
- PJ > TV
- offline
Very close, it depends on what you are watching. On Blurays, the JVC almost always wins, I've seen one or two blurays I thought the DLP still won just slightly due to handling noise in the image more.
Most of the time the JVC has the same POP as a DLP in even brighter scenes, there are a few scenes that will favor one or another. The JVC can POP more in some scenes.
For instance in the movie trailer "Dolphin Tale", there is a closeup of the boy's face / skin-tone and a couple shots of Morgan Freeman in a VERY bright outside shot, the JVC wins across the board, it makes the faces POP just as much but the skin looks a tad more natural and better on the JVC due to the tighter pixel fill ratio (we are picking this apart here, most people couldn't tell the difference).
Yet on a few other bright scenes, like far off scenery shots, I'd give the DLP the tiniest of tiny advantages, so slight it takes an eagle stare at the screen, the sharpness generally looks the same though. When you get snowy scenes, I preferred the JVC again because the snow looks smoother and more natural, but still POPs.
The JVC does have smoother pixels (not lack of sharpness, but tighter pixel fill), this is actually an advantage IMO more than a disadvantage. You do have to let your eyes adjust for a day or two in order to let the different looks be apparent.
It takes a dual-comparison to even tell the difference. I have a DLP side-by-side to the JVC, I've split screen them both, and A/B'd, and watched back to back content.
The only advantage I would still give DLP is poorer sources, and motion in sports and gaming. However, even here with noisier or faster moving content it is a very mild advantage and not always apparent. The JVC has a noise filtering option, and you can turn sharpness and detail enhancement off as well for noisier sources, and this is about the best damn noise control filter I've ever used. So even here the advantage isn't concrete to the DLP, because the JVC can smooth the noise out a bit more, but the DLP tends to just handle it better naturally (more of a preference though).
For some reason DLP DC 3 tends to process a "dirty" noisier image like on Netflix a tad better, it is probably because the more visible pixel fill hides some of the perception of the noise I guess (even if the noise is still there), I'm not sure exactly why.
Back to Forum: Digital Hi-End Projectors - $3,000+ USD MSRP
- DLP sharp with LCD/LCOS blacks
Currently, there are 1002 Active Users
(98 Members and 904 Guests)
Recent Discussions
- › No sound streaming MKV 29 seconds ago
- › Just received and mounted my new DNP Supernova BLADE 08-85 Screen. ... 1 minute ago
- › Good media players for 1080i CRT TV 2 minutes ago
- › help trouble shooting HDTV problem after new AV receiver 6 minutes ago
- › Official Pioneer Kuro Reddish Tint Problem Thread 7 minutes ago
- › POPCORN HOUR A-400 is coming soon 9 minutes ago
- › Wireless bandwidth requirement for 24/96 streaming over DLNA 11 minutes ago
- › Star Trek 2 12 minutes ago
- › ADA Mach 4......WOW!!!! 14 minutes ago
- › Denon AVR-X2000 vs Onkyo TX-NR626 18 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
