AVS › AVS Forum › Audio › DIY Speakers and Subs › Another 2 Wolfhorn SDX’s as a riser
post #1 of 12
Special thanks to Oklahoma Wolf for the design and to FUN4ME for the great use.
I was surfing around for riser ideas when I saw the "couch sub" danley sound labs was building so I started looking for a affordable DIY sub riser and found Mr. Wolfs horn. My sons and I started this last weekend and the first one is done and the second one is ready to be glued and screwed.
The riser will be two of the Wolfhorn sdx10 tapped horns powered by an EP4000, LFE will be supplied by a Yamaha AVS receiver via a Samson s-convert.
Thanks again Mr. Wolf!
post #2 of 12
Very cool! I look forward to seeing pics of these installed!
post #3 of 12
+1 nice work.
post #4 of 12
You're welcome
post #5 of 12
Thanks, We also finished the center channel/ screen holder box.
post #6 of 12
I think you hit a sweet spot with this one, Wolf. I like that people are using them.
16Hz tune gets you most all of the shake anyone would ever need in an enclosure that is not too crazy big.
JSS
post #7 of 12
Thanks - I was hoping this one would look a little more attractive than the behemoth I built last year. Probably helps a lot that it's a thin enough design to make risers relatively easy, and also goes a lot easier on the lumber. Never thought it would be real popular, but as long as I'm not the only person with one I'm happy.
I'm just pleased someone other than myself gets to hear what I hear.
Back to the pictures... wow, that's a lot of screws. Nice work though
post #8 of 12
JSS
+1,
The design seems perfect as a riser as has been demonstrated with this thread as well as another. It's also not too terribly wide, which helps with it's placement options to some degree.
Good job on the build modelaratrod! It's cool to see that you worked on it with your sons. I'd love to see pics of the full install.
post #9 of 12
How goes the fight? Do we need to send out a search party?
post #10 of 12
He has one done, maybe he cant leave it long enough to finish the next one.
I would love to have an EP4000 powering my subs
post #11 of 12
They were both finished on X-Mas vaca and we've been rock'n out every since!
Permagrin!
As far as making them part of the floor, that will have to wait till spring time.
post #12 of 12
Ah, excellent - glad they're doing what they're supposed to
