I have a rather interesting scenario I had with a 300 to 75 ohm balun. I hooked them up to my new antennas (I now use separate VHF & UHF antennas), & on the UHF antenna, I some how hooked it up wrong. The line that typically goes on the left terminal was hooked to the right side, & the right line on the left side. Anyway, the full power stations weren't affected by this (except for WCPX on RF 43, & pixelated on & off at different times, but were short), but certain low power stations were affected by this. I already have enough trouble getting WWME-LD, due to a sharp null toward Indiana (the null was set to protect then WZZM on RF 39, who went back to 13). I lost them, but translator W25DW-D on RF 25 actually improved. Since fixing this (left line on the left termainal & right line on the right terminal), WWME-LD comes back in, while W25DW-D pixelates (they pixelated with the old combo antenna too).
Could anyone explain why would hooking up a balun in reverse affect certain channels? I did include my TV fool chart, but don't believe that's really necessary. I should say that the VHF side wasn't affected, as I only have 3 VHF channels in Chicago (WBBM-TV on RF 12, WLS-TV on RF 7 (for now), & WOCK-CD on RF 4 (reason I bought the Antennacraft CS600 instead of the Y5-7-13)), & I had that hooked up properly.
I personally could care less about W25DW-D, but my mom discovered them by accident when flipping channels, & discovered HSN. She wants the channel, while I don't. I want WWME-LD, because of Bounce on 23.2. To my knowledge, those were the only 2 stations that were affected by the balun being hooked up wrong to my Winegard HD9032 UHF antenna.
