AVS › AVS Forum › Audio › DIY Speakers and Subs › Horn surround is alive!
post #1 of 24
This is my latest build:
horn surrounds with very high sens. based on 8" woofer and 1" compression tweeter loaded with a 20cm exp. horn.
Attachment 231825
Attachment 231826
Attachment 231827
post #2 of 24
the woofer is a powerfull Beyma 8G40 and the tweeter is a BMS 4550
Attachment 231828
Attachment 231829
Here the x-over: 1200hz 12db slope
Attachment 231830
hand made feet
Attachment 231831
post #3 of 24
That looks awesome. Very nice work. How's it sound?
post #4 of 24
Nice work! Those look great! I'm with Gooddoc, how do they sound?
dbl
post #5 of 24
looks great.
post #6 of 24
Very well IMHO, detailed mid-high, strong mid-bass, extreme presence with a good live feeling.
The only downside is the high fs (70hz), but you know, are surround!
post #7 of 24
Very very nice, love the tweeter wiring!
noob question: why go with a horn for a surround speaker?
post #8 of 24
I'm guessing--- Efficiency.?.?.?
dbl
post #9 of 24
dbl
95db 2,83v, I don't made some test in room now, but I hope that with room gain the sens. rise near 97-98db.
post #10 of 24
Because I woukd to paire at best with my other speakers:
You can see them here, post 906-907
http://www.avsforum.com/avs-vb/showt...646455&page=31
Merry Christmas to all!!
post #11 of 24
How deep is the horn front to the back of the CD for depth?
post #12 of 24
23cm total
post #13 of 24
Your horns appear to be of the narrow dispersion variety, any plans to upgrade?
Who made the horns? They appear to be nicely constructed.
post #14 of 24
Absolutely not, these horns sound like so much to me, at 1 mt. the dispersion is very good up 5 kHz, and 20deg. 20khz
Attachment 231985
post #15 of 24
Maybe I'm misunderstanding something, but an exponential flare is not a tractrix, and the trax image attached in the last post doesn't seem to be the same as yours based upon dimensions.
Who's the manufacturer of the expo flare you used?
post #16 of 24
+1 those don't look like any autotech horns I've ever seen.
post #17 of 24
In fact, I was wrong, my are tractrix horns and not exp.
Sorry for the misunderstanding.
http://www.stereo-lab.de/EN/spheric-...trix-horn.html
The horn of my last post is this, always tractrix
http://www.horns.pl/tractrix200.html
Another great European horn artisan manufacturer.
Hope this help
post #18 of 24
This trax on the image is similar to my front.
post #19 of 24
Similar in profile, but dimensionally much different. Without any other commentary, I thought you were implying they were your units.
I had some trax turned up out of laminated mdf for my BMS 4590 some years ago that were about the same size as the Autotech's you linked. Beamed like a mofo at HF and I went back to my Arai A290.
I see you've said they're Stereo lab units, which was my original guess.
post #20 of 24
Just curious why you got the textured finish. Is that who made yours, or was it a different company?
They're from Stereo Lab (click the first link in the quote of your last post) and they've been available since about 2000-2001.
post #21 of 24
I think the ones he bought are from Stereo Lab?
Autotech now has the tractrix models and quite a few other designs, only in a high gloss finish. They're the best built horns I've ever seen. Super thick and heavy. The picture on their site doesn't do them justice. I never got around to posting photos, but I should get some. When I removed them from the pallet and opened them up, I was really impressed.
I'm thinking about ordering some of the 350's for myself because they look so nice. But I'm trying to find a deep dark blue color first before making a decision. Might go with the funky Iwata 600's or E-JMLC-600's just to try them out though.
The current pallet is not completely filled yet, so there is room for more if anyone needs them. They sent me a new price list that takes effect AFTER this current group buy.....and it's higher on the larger items including the tractrix. That's another reason why I might get some of the tractrix 350's.
post #22 of 24
Sorry, I did notice that after posting, so I deleted my post.
post #23 of 24
I don't try Autotech horns, but I've only seen some pieces at home of my friends and they are well made IMHO
I try only Stereo Lab horns and I find them very good, the final result with a BMS 4590 and a little eq is exciting.
post #24 of 24
