AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › basementdweller1's "subbin' it out" basement theater & more build
basementdweller1's "subbin' it out" basement theater & more build - Page 5
post #121 of 128
Awesome looking room! Did you do any kind of lighting behind the screen to showcase the front speakers? If you have a photo of the speakers showing through the screen I would love to see that.
post #122 of 128
Originally Posted by basementdweller1 View Post
Alright here is my setup...
Blu-Ray, Apple TV, Xbox 360 all connected via HDMI to the 809.
A Cable box connected via Component Video and an optical cable for audio to the 809.
HDMI Out (Main) -> Epson Projector
HDMI Out (Sub) -> 2x HDMI 3D splitter -> two identical Toshiba 46L5200U LED tvs.
Can anyone help me see if I am doing something wrong with the setup. I pre-wired my newly constructed basement so I have very limited options for running more cables to the flat panel TVs, I was certain that an AV receiver would simply send audio data over HDMI out to an video source at the same time as it played audio through speakers. Am I dead in the water?
First off, AMAZING basement!!!!
Have you tried switching the cable box connection to just HDMI instead of component/optical? This would tell you if it is the optical connection put a wrench in your works or not. I am assuming that you ran it this way beacuse of having only 3 HDMI inputs on the 809? I have a 4x HDMI splitter that I have not hooked up yet but I am going all inputs to the splitter and then to my Onkyo and then out to LCD and Projector. This way audio and video are going HDMI in and HDMI out.
Good luck!!!
Luke
Edited by Lukedog17 - 8/9/12 at 9:24am
post #123 of 128
The room really turned out great!
post #124 of 128
Absolutely fantastic. A very classy setup. I love it!
post #125 of 128
Good luck!!!
Luke
First off very very nice basement. Over that's a dream basement nice job man.
You might try getting a HDMI 4x4 matrix this would allow expandability of your current system.
This one is rack mountable and fairly inexpensive at $499..
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158283&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
post #126 of 128
post #127 of 128
Yep, i went with a 4 x 2 matrix from Monoprice for my room. Should be finishing it all up and getting everything set up in the next couple months.
Luke
post #128 of 128
Very nice project. I am just starting to map out my project, you have inspired me.
