Originally Posted by Seegs108
Manni01's right. Picture quality and higher bit rate don't always mean the same thing. You have to look at how video encoders work.
Movies shot digitally usually have a lot less grain to the picture and will therefore not need anywhere near the same amount of information and bit rates won't be as high usually as well. Film grain takes a lot of information up because the image is changing so often. This always drives up the bit rate.
Considering how clean the source is from noise and grain high bit rate peaks will be rare on a movie like The Art of Flight.
You should throw something grainy at it.
True although to be fair Jason never mentionned high bitrate but fast paced, so he might have used AofF to test stutter as motion in AofF seems indeed so fast paced, and therefore would be a very good test to detect that. Also grain by itself doesn't garantee high bitrate, as some blurays are sadly made from poor masters initially made for DVD and give you grainy and poor quality picture with medium bitrate (I'm thinking about movies like The Fugitive).
The bitrate question was a kind of separate question of mine as I am genuinely interested in finding out the peak bitrate of that title. Given the price of the bluray, I haven't bought it yet and a super high bitrate might convince me to pull the trigger
The only way to be sure about the bitrate is to look at the actual real-time bitrate of the movie (in scenes where there is intense motion and complex pictures, so outdoors travellings are usually a good place to start) which you can display in most software and hardware players, including mediaplayers like the Dune. The size of the main m2ts is only an indication if the movie is less than two hours (in which case if the main m2ts file is close to 50gb without the bonus, it's usually high bitrate).
![A Turtle's Tale: Sammy's Adventures [Blu-ray]](http://cdn.avsforum.com/e/e9/50x50px-ZC-e9458a66_B006US3UPS-51izvYOMfnL.jpeg)
Of course this is very much a YMMV type of thing, but man this is where these JVC projectors really suck (to put it bluntly) as far as 3d. Movies are bad enough, but games are ruined IMO from the excessive crosstalk in general. Throw in the flicker and my 3d use overall has been VERY minimal with movies and like I mentioned, games are not even worth playing in 3d due mainly to ghosting (the detail/resolution loss is no good either, but for me the ghosting is far worse of an issue) the last 4 months.
