Originally Posted by Toe
If the HP was such a bad 2d screen, my ST130 would be back on the wall. My ST130 has been in storage ever since getting the 2.8HP.....and that was almost 2 years ago.
No, it is not just brightness either. Being able to mount my JVC at max throw and iris clamped all the way down (for 1.78) for max contrast is something I could never do with a low gain screen and still get good brightness. The HP/JVC is a perfect match IMO due to this IF you have the right setup for it.
No, it is not just brightness either. Being able to mount my JVC at max throw and iris clamped all the way down (for 1.78) for max contrast is something I could never do with a low gain screen and still get good brightness. The HP/JVC is a perfect match IMO due to this IF you have the right setup for it.+1
![A Turtle's Tale: Sammy's Adventures [Blu-ray]](http://cdn.avsforum.com/e/e9/50x50px-ZC-e9458a66_B006US3UPS-51izvYOMfnL.jpeg)
I need to make sure whatever place I get has the wall space. If not I'll just go with a smaller screen.
