AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Redskinema - Nearing completion!
Redskinema - Nearing completion! - Page 2
post #31 of 605
and w 3d renderings....
post #32 of 605
The 3d render post moved the thread to page two, just wanted to say that if you go back to my last post on page 1 I posted 4 images of the blue prints with dimensions
post #33 of 605
If anyone has any suggestions place throw them out there. The design is still fluid right now but this saturday I might be breaking ground and starting some framing!
post #34 of 605
Let's talk about sound management. If you are starting to frame then spend the extra $100-200 or so and isolate the wall framing from the ceiling joists. That way the sound/wall vibration from the subs will have a more difficult time making it upstairs to disturb your significant others.
Plan for clips and channel on the ceiling and double drywall with green glue all around. Having done it I can tell you that it will contain the theater rumble.
post #35 of 605
I hate stairwells. They keep me up at night. I would be careful about using that space under the stairs for equipment. Convenient but the biggest conductor of sound up and out of that room.
post #36 of 605
It would be pretty easy/cheap to treat all the surfaces under the stairway as you would the theater.
post #37 of 605
Well, yes and no. You have to frame a cube or rectangle, then apply clips and channels to all these surfaces, insulate and then apply double drywall. Pretty tight quarters become even tighter.
Also hard to get competent ventilation in there without compromizing what was just built.
Can and is certainly done, but it's not as straightforward as the walls, and you wind up with a surprisingly smaller space, making it maybe less than worthwhile.
post #38 of 605
Actually I don't see any opening from the theater to the under stairs equipment rack. If he were to add clips and channel to that stairwell wall and the nook for the sub-woofer he should be pretty good. The other walls I would rip down and rebuild with the same materials only 3/4 of an inch shorter and with clips, The reason I wouldn't rip the stair wall down is I bet it is secured to the stair stringers and gives the stairs a lot of rigidity, But you could stagger stud that wall as an alternative by popping in some additional studs sticking out an inch.
post #39 of 605
You can't rip the stair wall down, surely. I agree.
Converting the single wall to staggered would be less efficient than removing the drywall and attaching clips and channels. Best would be to have an independent 2x4 wall in front of that stairwell wall.
But as my pal Mick says, you can't always get what you want.
post #40 of 605
Rip down what drywall?
post #41 of 605
That was fast!
post #42 of 605
Why does a stairwell keep you up? What noise does a rack produce?
post #43 of 605
This was an old design that my installer did. I redid it myself and the new drawings are in the post.
post #44 of 605
That was fast!
Haha yea only took a few hours to demo the basemet! Putting it up won't be as fast... I'm going to try and frame in the theater this weekend so I can get my electrician in to wire everything that I need added.
post #45 of 605
I get why you would stagger studs in a theater but for an equipment room?! Am I missing something?
And my new design doesn't put a sub under the stairs. I don't like that option. The installer was trying to save my room depth.
post #46 of 605
Do you have a link to where to buy clips?
What do you mean by channel on the sealing?
post #47 of 605
soundproofingcompany.com Ted's company. Check out his articles there first.
Whisper clips and hat channel essentially mounts the ceiling drywall on "springs" keeping the sound from making it's way upstairs.
He also has clips for anchoring the top plate of the walls.
post #48 of 605
That was fast!
Can I schedule a time to speak with you today about sound proofing my room?
post #49 of 605
Sure thing. Send me a PM if there's a good time.
A rack area under the stairs isn't in and of itself a problem. As pointed out, the racked equipment doesn't create noise. I have a rack under the stairs also, but the air space under the stairs is NOT open to the theater. I access the equipment from a little lobby before I enter the theater. So not a problem.
Often we see designs where the back theater wall is the stairwell wall and there's a planned large opening in that wall for a rack. This obviously allows sound to directly vibrate the stairwell framing. That's what keeps me up nights...
post #50 of 605
Big, how far away or for how long do you surpervise builds?
post #51 of 605
I pretty much restrict my travel to this planet. I can usually stay as long as it takes. I charge by the hour so the longer the better.
post #52 of 605
When you say "this planet" you're referring to Earth? Just want to make sure we're on the same planet here...
post #53 of 605
I think the Vogons refer to their planet as "Earth" as well. You need to be more specific.
post #54 of 605
Yea, Big. Sheesh. You're normally pretty detailed and specific.
post #55 of 605
That makes a lot more sense now, thanks for clarifying. Im makign sure to keep the theater separate from the equipment closet.
post #56 of 605
OK, I'll be more specific any place I can get to with a US passport.
post #57 of 605
I got exact stair case like in this picture and I was also thinking to use it as equipment closet, but my rack is too high to fit in there and this is what I end up with:
post #58 of 605
Wow, that's efficient use of space. And per Big's earlier comment, that sort of space under the stairs is clean and easy to decouple and drywall. Not as straightforward (to me, anyway) when going through the side walls of the stairwell.
post #59 of 605
And I also got a small storage space under the stair case, so no space is wasted. I didn't do clips and hat channels under the stair case, the space is too tight, but I do have double 5/8" drywall and green glue in between, since that space is off the main side wall, sound waves will not direct hit that space especially, the side wall will be treated so I think I can get away without using decoupled wall there.
post #60 of 605
Im going to do the same thing walk, but only on one side. the other will be enclosed for the back wall of my theater. Im opening the other side so it makes the basement feel more open when you walk down. And will allow you to see my, in theory, awesome bar that will go there!
