AVS › AVS Forum › A/V Control & Automation › Remote Control Area › HELP - Onkyo Standby with Insight Remote
post #1 of 5
Is there anyone out there who knows how to program an Insight Cable remote to BOTH turn on and turn off my Onkyo TX-nr609? I have owned three Onkyo's over the past ten years and it seems all of them require a separate signal to turn it on and turn it off.
I don't know if that's still true, but the cable remote still can't turn the Onkyo off, even though it can turn it on.
Any help would be greatly appreciated.
post #2 of 5
what code got you the onkyo on command?
just want to be sure who makes this remote.
post #3 of 5
Interested in this as well. I have insight and a onkyo 609 and can only get it to power off or power on and control volume. All I really want is to power off/on, and control the volume.
Just for reference here are the codes I used:
http://www.urcsupport.com//images/up...T_M2067BX3.pdf
30135 Will Power on and control volume.
30842 Will only power off.
For now I am using 30135, I figure if I can get it on I can let it auto stand-by when I turn everything else off. The manual says this takes 30 minutes to work, which is longer than I like. I wonder if this is some how reprogrammable? Maybe a firmware update? However, I can't get auto stand-by to work? The manual doesn't give much help on it either. I powered off my cable box when I went out to dinner tonight and was gone just over an hour and when I got home it was still only displaying CBL/SAT No Signal instead of going into stand-by.
post #4 of 5
post #5 of 5
Originally Posted by 3FingeredGlove View Post
See post #42.
Worked like a charm.
  Back to Forum: Remote Control Area
