I'm trying to put together a 5.1 system for around $500. I know that won't get me much, but anything would be better than the HTIB I have now (Philips HTS3372D). I play a lot of games, watch movies frequently, as well as listen to music (mostly hard rock and heavy metal). The room is about 25ft long x 15ft wide x 8ft tall.
Right now I'm looking at:
Fronts and rears: Sony SS-B3000
Center: Sony SS-CN5000
Sub: Recommend me one under $200 (around $150 would be better).
I have already purchased:
Receiver: Denon AVR-1611
I'm pretty much set on the B3000's as they seem like a really good speaker for the price, but I'm open to suggestions.
EDIT: I went ahead and ordered a refurbished Denon 1611 from Accessories4less for $221 shipped. They have a deal now which includes a free Denon i-Pod dock with the purchase of any Denon receiver. The dock sells for about $40 to $50 on ebay, so I figured I would go ahead and get it and sell the dock since I have no use for it. I should have said earlier that right now I have my set up in a 13x13x8 room, but I am moving it to the bigger room within a few weeks. I have an old set of satellites from an old RCA HTIB that should work until I move rooms and have room for the bigger Sony's (I don't want to use the ones with the HTIB I have set up now since they have an impedance of 4ohm, but the RCA's rated at 6ohm and should work for now). It looks like I can not connect my passive sub to the 1611 (other than wiring it into the front channels), so I'm going to try to get a sub right now as well. I was looking at the Polk PSW505 on Amazon (the price was $169 new and $150 used yesterday), but the price keeps fluctuating. Newegg had it on sale as well, but they are now sold out. The BIC F-12 is at $188 on Amazon right now, and it is looking to be best choice but will put me slightly over budget. I have never owned a powered sub and the sub I have now only has a 6.5" driver, so it will probably not take much to impress me.
