AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Is there a Universal Remote App for a Laptop?
post #1 of 6
Is there an application similar to iRule or Roomie (which are made for iPods, iPads and iPhones), but that runs on a PC? A spare laptop with 802.11 controlling my A/V equipment using a iTach box would make a great coffee table remote.
I have been happily (after the initial effort to set it up) controlling things with a Harmony 890 Pro for several years, but it has now broken. The interface port broke off inside the unit when trying to revise things to add a Blu Ray.
Rather than sinking money into a waning product, I noticed that there have clearly been notable advances thanks to the "There is an app for that" world. It seems many are using their mobile devices as a universal remote control using apps like iRule or Roomie, but I have not yet embraced the smart phone direction... yet.
Why couldn't a laptop have similar robust features (macros, custom buttons, universal control, zones) using iTach equipment to make the TCP/IP to IR conversion (for equipment that does not have a Ethernet port). The key difference (pun intended) being it would be point and click, rather than a touch screen like the iPxx (iPods, iPads and iPhones) based solutions.
Anyone know of a good one?
post #2 of 6
A good one? How about Control4?
I disagree with your assertion that dedicated handheld remotes are a waning product.
post #3 of 6
I just discovered TouchControl. It is meant for iPhone/iPod/iPad BUT you can also have a remote on your PC. There is a function in the program for exactly what you're talking about. And it is completely customizable. Give it a look.
http://www.touch-ir.com/
post #4 of 6
I took the OP's comment to mean that Harmony was waning, not handheld remotes in general. I agree with that as each new generation has some functionality removed that its predecessors had. I agree with you also, the ipad type solutions have a WOW factor, but the handheld remote cannot be beat for some uses, such as DVR.
post #5 of 6
Yup, the comment was specific to the Harmony 890 Pro, not handhelds in general.
That said, my requirements (albeit far and wide) seem to be pushing handhelds out of the equation. I am looking for affordable, RF (non-line of sight), super macros, multi-zone, fully customizable, 100% reliable and most importantly usable by anyone, not just the technically gifted
The RF part generally means they are not affordable when looking for a handheld solution. When I decided to bite the bullet on price and go with the Harmony because it was RF and customizable, it proved to be reasonably reliable (not 100% but pretty close) but it was a bear to set up and only lasted a couple of years... and they did not stand behind their product - No affordable replacement option nor a solution that was backwardly compatible, which would have meant more time spent setting up a new Harmony model (uhhh, NO - once bit, twice shy).
For me, today's remote technology means:
* RF = 802.11
* Affordable = using a smart device that I have justified for other reasons.
All the other high tech functionality also seems to be pushing me toward a PC or iPxx device.
I am definitely going to try TouchControl. So far what I have read seems to meet all of my requirements. I have not looked at Control4 in any depth yet, but the MyHome product says "must have a Control4® system" and to contact a dealer - sounds expensive.
Thank you all for the input. I appreciate it as I now have a direction to take.
post #6 of 6
TouchControl is the app for me. In addition to the functionality in today's leading Remote Control applications, I was looking for 2 additional things that I needed:
  1. Using a laptop PC as the User's remote (the reason for this post) - Many people have wireless laptops and many apps are designed for iPxx devices, yet only TouchControl allows control using a laptop PC as well as iPxx devices as the remote. VERY UNIQUE, VERY USEFUL, IMHO.
  2. Controlling a Panasonic Blu-Ray (DMP-BDT110/210/310) over the network (TCP/IP). With TouchControl's help to figure out HTTP POST and input from mdavej and XARiUS, we cracked this nut too. I have posted the technical details on the command format here: http://www.avsforum.com/avs-vb/showt...5#post21491715
TouchControl includes these two requirements at an affordable price, along with the commonly needed functions such as:
  • Customization of remote layouts
  • Macros
  • 802.11 for non-Line Of Sight control
  • IR for traditional control (using a iTach device or equivalent)
  • iPxx as the User's remote
I am very happy thus far. I am not affiliated with TouchControl other than a very impressed user. Check it out at http://www.touch-ir.com/.
  Back to Forum: Remote Control Area
