Hi,
My SONY 50XBR800 is about 9 years old. Recently the lamp went out and I replaced it with one from Amazon.
Everything was fine for a few weeks, then the problem started. The TV powers downs for about 30 seconds every 10-15 minutes. The standby light blinks a few times, then the picture comes back on and the picture is fine.
I thought it might be the lamp, so I ordered a new one from DLP Lamp Source. However, when I inserted the new lamp, the set does not turn on. The standby light blinks, the new lamp makes a static sound every minute or so, nothing else happens. DLP Lamp Source immediately replaced the lamp, but the same thing happened with the replacement. BTW, DLP Lamp Source is excellent.
Any ideas what is going on? The two lamps have totally different symptoms.
Thanks in advance,
Paul
Thanks in advance,
Paul
