AVS › AVS Forum › 3D Central › 3D Tech Talk › Please help with hookup tips for 3D
post #1 of 7
Just picked up my new Panasonic TC-P55GT31 55" Class 1080P Plasma HDTV. Looks great while using it in 2D. Charged the glasses and tried it in 3D but it isn't working right at all. I have it hooked up to the Panasonic DMP-BDT210P Blu-ray Disc player. In need of some advice if anyone can help with this!
post #2 of 7
Read the manual from your 3d blu ray player and your 3d tv.
Follow the instructions.
post #3 of 7
I'm doing that now. But it seems to be correct. Double checking it again. The 3D is really fuzzy. Doesn't appear to be working at all.
post #4 of 7
Go to the setup settings of your blu ray player > disc > 3D BD-Video Playback
Don't know which options you will see, but automatic or frame sequential is probably the one you need.
The TV should automatically detect the 3D format and switch to 3D mode (I also have the GT30).
Btw make sure you are playing a 3D content (from a 3D blu ray disc) and turn your glasses on.
post #5 of 7
My glasses don't seem to getting the infa red signal because they keep turning off
post #6 of 7
What content are you testing it out with?
If it is 2D to 3D conversion?
You need to try some real 3D content on it for proper eval.
post #7 of 7
It works! I had to move my sound bar. It was blocking the signal. Thank you for all the help. It looks absolutely AWESOME!!!
  Back to Forum: 3D Tech Talk
