AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Highland Park HDTV
Highland Park HDTV
post #1 of 2
Anyone else out there in the Highland Park, IL area? I was taking a walk with the family yesterady, and noticed a newly constructed house with an antenna on the roof. Naturally this caught my eye. Upon closer inspection I noticed the antenna has a rotor and that there was a DirectTV multi satellite dish next to it.
Just wondering if the rotor allows reception of any of the Milwaukee stations. I sure would like to see the PBS demo loop.
The house is in the Sherwood Forest neighbor hood.
Just wondering. And by the way, this is a truly "local" post.:D
JT
post #2 of 2
In Highland Park you might be able to get Milwaukee. I don't here in Downers Grove, but I have a rotor, as I want to try to pull in Rockford stations when they come online.
It wasn't that hard to install the rotor last month, and I would suggest that you try it. They are pretty cool and not very expensive or complicated. Good luck -- I would like to see the PBS demo loop too, but WTTW won't show it, even though I asked the Director of Engineering to put it on.
This thread is locked
