Question: I got the HT-CT150 for Christmas. So far it sounds pretty good, but I can hardly ever get it to switch off of LPCM. I'm not a home audio buff and I'm not even sure of its capabilities. I do know that LPCM seems to be a far inferior method than Dolby 5.1.
When playing Blu-Ray movies it still says LPCM despite me having turned on *every* audio option under the audio settings. I cannot disable LPCM under the audio section.
Is this something I should worry about? Should I attempt to get it to play in full 5.1? Any help would be appreciated. Thank you.
EDIT #1: My set up is PS3 connected via HDMI to HT-CT150 which is connected to Samsung HD TV via HDMI. Or in short... PS3 -- HDMI -- HT-CT150 -- HDMI -- Samsung TV
EDIT #2: Update: After much searching I've realized I needed to convert my audio to "bitstream". Under the Playstation 3's audio settings there are no such options. Apparently I needed to go under the video settings for Blu-Ray & DVD audio playback and change it form Linear to Bitstream. This appears to have fixed my issue; but still – I would appreciate any clarity that anyone would like to add
I'm somewhat of a n00b.
