AVS › AVS Forum › Audio › Home Theater In A Box › Panasonic SC-BT230 help please
post #1 of 5
Hi, i hope this is the right place for my question if not sorry.
well i have this set for about a year plus my Panny TC-42Px24 plasma and having some really good time with them but after getting the PS3 connected plus my Wii i have to keep changing the audio inputs for each set, what i wish to know is if there is a setting or something that will make the tv/ht change to it's correct audio preference everytime i select the ps3 (via hdmi/toslink) and the wii (via componet/tv-toslink) because let's say i am playing ps3... if i change to wii video the audio will still be the one used with the ps3, sorry for my english and i hope you guys could give me a hand with this P.S. TV/HT are linked with viera link just in case.
post #2 of 5
A universal remote like the logitech harmonys can help you with that. Basically you set up the remote with different activities like for me I have movies or karaoke. I push the movies button it turns on the tvand sets the receiver to the right input. I want karaoke, it does the same thing. The lower end models like the harmony 650 would be perfect! Hope that helps!
post #3 of 5
Hi pokekevin and thanks for your suggestion, yeah i was thinking about buying one of the cheap ones like the Logitech Harmony 300i or the Logitech 915-000148 Harmony 200, do you think they will be able to do what i want? if that so i would buy the harmony 200 because i don't need extra features just want to switch the audio to the correct video :P, any help you or other guys could give will be appreciate, thanks alot.
post #4 of 5
The cheaper Harmonys control fewer devices. If you have a TV, AVR, cable box, and two game systems, you are already up to five. So, check the Harmony specs before you buy.
post #5 of 5
Well yeah but i can't control the wii and i think the harmony use ir and not bluetooth so i can't use the ps3 with the remote (not that i really care because i would use my bluray home theater) unless i buy a bluetooth adapter or something like that for the ps3 :P so im resume i will just use the avr (bluray home theater) the tv and the cablebox, but correct me if i'm wrong please.
Oh have someone tried the Logitech 915-000148 Harmony 200? would it program the audio preferences for each set too? or should i go for the 300 that have some more features and an extra device for 6$ more? (i'm in a budge and i don't really think i will need the extra features for the bigger brothers for the amount of money they cost) :P thanks for any info and to BIslander and pokekevin for the info.
  Back to Forum: Home Theater In A Box
