AVS › AVS Forum › Audio › Speakers › supercube 2000 vs supercube 4000
post #1 of 8
so i just upgraded my sub from a def tech pro sub 1000, to a supercube 2000, wondering if i should bump it up to the supercube 4000 instead. your thoughts are as always appreciated!
post #2 of 8
Might want to try the sub forum, though you won't get much help since not many here have ever heard or used either one.
Unless you have space constraints that limit you to subs of that size you'll be recommended to go with an internet direct sub like SVS, Epik, HSU etc...
SVS makes a 14" cube with a 12" woofer that should provide much better output than either of the subs you've mentioned.
http://www.svsound.com/subwoofers/se...&category_id=6
Gene
post #3 of 8
Gene
those are a bit out of my range, i paid 300 for the supercube 2000 and i can get the 4000 for 400
post #4 of 8
also if anyone knows the advantages of the class HD amp in the 4000, id love to know
post #5 of 8
Send a message to Joe in the Def Tech forum. He's from Def Tech.
post #6 of 8
ended up exchanging it out for an order of the supercube 6000, got an amazing deal on it the 2 subs above it they sell are out off my price range and probably completely unnecessary for what i need and want, just gotta wait a few weeks without any sub for now
post #7 of 8
Those are amazing prices. Any more available at those price points?
post #8 of 8
HI,
Can you please tell me where you got that great deal on supercube 4000. I have not found anything under $550.
  Back to Forum: Speakers
