AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Source of my TVGOS problems?
post #1 of 13
I just had a comcast service rep at my place, on Christmas day I lost about half of my channels, and my internet service went out 2 days later, . He told me that my line input was bad and just switched me to another(I'm in an apartment complex)
presto, bango, everything is up and running
Question is: My TVGOS had been out on My panny EH55 for about 2 years now, and I've gone thru ROVI and all the assorted testing.
Is it possible that this bad lead in that just a week ago caused me to lose channels, actually may have prevented me from receiving TVGOS long ago?
What are your thoughts?
I am resetting my units (again) and only time will tell, but maybe THAT was the source of my problem
Bill
post #2 of 13
Only if you were not at all receiving the channel carrying the TVGOS data.
Even if it were weak and fuzzy, something would've come through, and you would've at least gotten smatterings of data.
post #3 of 13
Bill, FWIW, I know that, with my old Pio 531, ANY removal of r disturbance to the coax signal would kill TVGOS in that DVDR. Once I tried a backwards splitter (as a combiner), which didn't work for combining, but it DID knock out my TVGOS.
post #4 of 13
If we're talking about a Pio, then yeah - I suppose anything could happen, regarding the TVGOS. Those were uniquely bad, as far as the TVGOS implementation. But that's not how a Panasonic with it would perform. All the ones I've had would've behaved like I detailed above.
post #5 of 13
Exactly what are you referring to when you say "bad lead"?
If the wiring or connectors coming in to the recorder are bad anywhere on your end, then you should replace them.
post #6 of 13
the lead was cutting off certain bandwidths (and therefor "some" channels)..and was lowering the signal by a few dB as well.
so he just switched me over to another one... (i went outside and looked, there mustve been like a 30 way splitter in that box feeding a few apartment building and their units)
post #7 of 13
not the lead wire...but i should say a bad TERMINAL on the outside panel (cable company access only)
nothing that I had access to was at fault
post #8 of 13
It has been mentioned in the Philadelphia OTA forum that TVGOS is not working on the CBS stations in Philadelphia and New York. They expect it to be up and running sometime early next year. I don't know where you are but you may have a similar situation.
post #9 of 13
detroit...and according to the local avsforum there, the cbs here is running....
post #10 of 13
I just checked out that forum. 14 screens!
post #11 of 13
college football heaven......
post #12 of 13
I guess that the source of my tvgos problems were more of a rovi thing than anything else
I liked the feature while I had it
post #13 of 13
They had apparently discontinued the service in your particular area a bit earlier than elsewhere from the time stamp of your initial posting. It was a nice feature, and while there is still some information available through the PSIP functions that isn't as extensive or able to look as far into the future as the original TVGOS function.
  Back to Forum: DVD Recorders (Standard Def)
