AVS › AVS Forum › Audio › Speakers › Speakers for Television - Low Budget
post #1 of 6
I am in the market for speakers for my father's television. I am looking to keep a low budget (under $200 is definitely where I want to be). I basically want something that will be a marked improvement from the built-in speakers on the television. I want to use this to be a base to build a sound system step-by-step.
I do not have a receiver, and am not sure if one is necessary. I have the Swan M200 MkII in my own place and love the sound.
Please let me know if any of you have any suggestions. Is this doable? Thanks again!
post #2 of 6
If you like the Swans, why not get them for your dad?
post #3 of 6
I saw some Sony SSF-6000 speakers on amazon yesterday for $120/pair. That would be good for you if you want floorstanding speakers. Nice price.
If you want a bookshelf/monitor type speaker, the Polk Audio Monitor 40 is a good speaker at $150 on Amazon or the Polk Monitor 30 for around $100.
You have to have an amplifier or receiver to drive the speakers.
You can go to the Sony website and get the STR-DH100 stereo receiver for $99 direct from Sony. Get the Sony SSF-5000 speakers from Amazon for $100 and you are in at $200.
Make sure that the TV has analog audio outputs to go to an amplifier or receiver; some sets do not have them (two RCA jacks, L and R).
If it doesn't you need to get a receiver with an optical digital input (assuming the TV has an optical digital sound output, which most do).
If you want a multi-channel receiver for expanding to an HT 5.1 -channel system later, the Onkyo TX-SR309 is a cheap option for $180 on Amazon. It has both optical and coaxial digital audio inputs as well as 5 analog audio inputs.
post #4 of 6
Remember, he doesn't have a receiver.
It'll be a little tough to get a receiver and two speakers unless he goes ultra cheap like the Dayton speakers for $39/pr.
http://www.amazon.com/Dayton-B652-2-...5268601&sr=8-1
post #5 of 6
Unless you buy him some Swan speakers - then this is one of the few options
Infinity speakers
http://www.amazon.com/Infinity-Primu.../dp/B000LKC37W
Sherwood receiver - and it is decent.
http://www.parts-express.com/pe/show...number=252-125
When you build up in the future - donate the Sherwood receiver, and use
the Infinity for surrounds.
post #6 of 6
The Audioengine A2 is about $200/pr. I have their A5's attached to my TV.
I think that to "build a sound system step-by-step", you'd really want to start
with an amp or receiver and (passive) speakers. Otherwise, integration is at
least more difficult.
  Back to Forum: Speakers
