Hey,
I'm looking for a projector to use in my home theater; but I don't know what I should be looking for.
The projector will be place on the ceiling (8ft). The distance from the projector to the screen will be roughly 15ft.
The largest size of screen that I can use (if its even possible to get this size) is 8ft (height) and 11(width); while still keeping it centered with the projector.
The room has no windows and once the door is closed it becomes pitch black.
Also what type of screen would I need, if any at all.
Budget: $3000 max but the cheaper the better.
First Row Seating: 13ft ish
Second Row Seating: 18ft ish
Room: 20.5L X 18.5W X 8H (square room)
Projecting: Movies/HDTV/Sports/Xbox360
3D: No
Ambient Light: None (The room just has 6 pot lights on one switch. No windows)
Lag: Minimal (30ms or less)
Room Color: Ceiling: White Walls: Sandstone Beige (aka light brown)
So, when looking through these forums, what should I be specifically looking for when it comes to a decent projector. (ex. brightness, lumen, lens type, software, etc.)
Thank you.
3D: No
Thank you.
My boys would have not been happy with the lag. They said, who cares about 3D after hearing about the lag.
"Lets do this"
