AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LCD Flat Panel Great Found Deals! › Looking for a good 32in LCD for under $400
post #1 of 3
Hey guys, I've recently been looking around for good deals on 32in LCDs at the stores around me, and online. I'm seeing some decent deals, but I'm not sure if I need to spend the full $400. Basically what I'm finding is that the 720p sets are closer to $300, and the 1080p sets are a lot closer to the $400 mark. Is it worth it to get the 1080p? And also, will I be fine playing Xbox with a 60hz set? I don't really even want to spend $400 unless absolutely necessary. I'm looking for a TV that is going to be good for playing Xbox and watching TV and movies on in a decent size bedroom. I cant go any bigger than 32" right now. I won't have an HD source for the cable tv so it's not going to make a huge difference in that area. Does anyone know of any good deals that are around right now, or will be coming in the near future? I don't need a ton of crazy features, just a good picture and good performance. Any help is appreciated.
post #2 of 3
I've seen this TV for as cheap as $400 recently at Best Buy and Ebay(sold by reputable store). 1080p, led, ips
http://www.adorama.com/PCTCL32E3.html
Mike
post #3 of 3
another option....not quite as high spec as the Panasonic Mike listed, but we're happy with it, and it was under $300 at both Walmart and Best Buy recently.
LG 32LV2400
It's 720p, but for the 32", I personally don't think that's really an issue (IMO), but might depend on if you plan to watch Blue Ray and how far away you will be sitting.
