AVS › AVS Forum › Video Components › Video Processors › Please Help with Iscan Duo setup
post #1 of 2
Hi i have the following devices,
Sky HD set top box
PS3
Apple TV
All are connected via hdmi
Please can you suggest the correct settings for the iscan duo for each device? How should i set the input/output colourspace etc, deinterlace mode, mosquito noise etc. There are lots of settings and much to mess up, i am sure there is a better way than just guessing. I know nothing about 2:2 pulldown etc, and ive read up on it, i just dont get it. whats the best way to get rid of the lines through text on some adverts broadcast on sky history hd? All help appreciated.
Mark
post #2 of 2
If you haven't already done so, the first thing you should do is calibrate your display. The Duo has test patterns built-in for this. (You can also buy third-party software to automate the process.) You should adjust your sources only after that.
Btw, the main iScan Duo threads here are http://www.avsforum.com/avs-vb/showthread.php?t=1180042 and http://www.avsforum.com/avs-vb/showthread.php?t=1286122.
Edit: If your Duo is connected to your display through the Denon AVP, you should connect it directly for the display calibration.
  Back to Forum: Video Processors
