AVS › AVS Forum › News Forum › Great Found Deals › Advent AV370 2.1 powered speakers $19
post #1 of 3
I found these at the W6TRW swap meet (Northrup Grumman parking lot, SE corner of Marine Ave. and Aviation Blvd., Redondo Beach, CA. which is held mornings until about 11am on last Saturdays, so the next one will be January 28, 2012.
Advent is a respected speaker designer/maker and these are not the usual gutless plastic wonders. In fact the boxed set weighs over 32#. It claims 10+10 and 30 watt amplifiers. Based on the manufacturer's reputation and the weight, I tend to believe they mean honest RMS at low distortion. The speaker with controls has bass and trebel as well as volume controls. Plug these into the 3.5mm headphone jack of a portable CD player or radio and you have a perfectly good dorm or apartment stereo.
post #2 of 3
I had this exact set, and was quite happy with it for several years. It *was* prone to static if you perturbed the connections even a little bit; but the sound was surprisingly decent.
After a few years, though, the sub started making an ugly "BRRAKK!" noise on hard bass hits. Thinking I would inspect the driver, I opened the enclosure, and received a not-so-pleasant surrprise: the driver is inside a totally sealed (as in glued shut) compartment. After some enthusiastic chisel-wielding, I got to the driver itself. As expected, it had a foam surround, and it had crumbled to dust.
Unfortunately, the plane the woofer is mounted on is *also* glued in place.
Bottom line: unless you're into carpentry, you'll probably want to toss this set once the driver in the sub goes boom. Of course, for $19, it won't take long for you to get your money's worth.
post #3 of 3
Perhaps you could build a replacement sub and transplant the Advent sub's amp. Would that be a reasonable project?
  Back to Forum: Great Found Deals
