So, I started over with only two devices. My TV and Cable. I programmed both manually, learning every key and was very meticulous to make sure every key showed "ready" and "saved" during the process.
I learned all of the TV keys and then tested the remote. All keys worked fine.
I then learned all of the the cable boxes keys manually.
After learning the cable box keys after the TV keys: Volume keys work, Mute does not work. Only channel - works, channel + does not. Menu and Info do not work, but Guide does work. "1" key works, "2-4" don't work, "5-0" don't work. All keys programmed into the LCD Main screen function correctly.
