AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Official URC R40 Thread
Official URC R40 Thread - Page 3
post #61 of 185
Originally Posted by chappy16775 View Post
I'm getting fed up with the delay or lag from my Harmony 650. I'm using it for XBMC software and the lag is noticeable when scrolling lists.
Can anyone tell me if the experience would be better on the R40?
There is no lag on my R40 - it sends the command instantly when i press a key.
One caveat though - to send a command that is placed on one of the 6 keys surrounding the OLED screen, you have to press the key once to "wake up" and illuminate the screen, then press the key again to actually send the command. Any key on the remote will wake up the screen but for one of those 6 keys to work, the screen must be illuminated so i only use those 6 keys for secondary commands (like settings menu or input changed etc). You can set the duration that the screen stays illuminated (choices are 5 seconds, 10, 15, 20, 30, 40, 50, or 60 seconds).
All the other keys on the remote respond with the first press and work normally.
post #62 of 185
OK so its not like the Harmony where simply picking up the remote will wake it up.
post #63 of 185
I'm interested in this remote, but have a concern about the placement of the volume and channel buttons. Though I haven't handled this remote, it seems to me that these most used buttons should be lower down, at least below the circle buttons. Do any users feel the same way?
post #64 of 185
I like the layout of the R40, I heard there were some issues with the R50.
No problem using it without looking for most functions.
post #65 of 185
I'm also fine with the layout. In most cases, it's the best remote I've yet experienced.
The volume and channel up/down buttons are a little high but no different from my MX850 remote.
If I were to improve the remote, I would add a couple more different textures to the finish of some of the buttons. As it is, the main and page buttons have a harder finish which makes them easy to distinguish by feel. I would give the volume and channel up/down a different texture and the four favorites/color buttons a different texture to help "section off" the remote. It would then be near perfect. Oh and add RF control. Perfection!biggrin.gif
post #66 of 185
Started programming my R40, and it didn't take 10 minutes before it seemed like I was programming my OLD R50; they're nearly identical in layout and programming with a couple of key/menu variations. So far, the good is:
1) They definitely used different parts/hardware for the buttons and I like the tactile feel. The reason I went for the R40 is that some of the buttons on my R50 started sticking BADLY
2) As is expected with a "newer" model, there are more pre-set codes in the R40, particularly in the "Aux" category (I found my Da-Lite screen codes which were a b*tch to learn on my old remotes).
While the screen is smaller, the overall remote is smaller/lighter as well (with smaller buttons), but that's OK since I have small fingers.
post #67 of 185
Just got this remote. I agreed the placement of the Channel and Volume buttons are too high. I keep having to remind myself (by looking at the remote) where the Channel and Volume buttons are. I also would have like them to be bigger.
Edited by benlwong - 12/21/12 at 6:35am
post #68 of 185
I have a MX-450 and bought a R50 for another TV but thought the quality wasn't even close to being the same. No knock on the R50, just didn't like the feel as compared to the MX-450. While I like the 450, I like the MX-780/R40 layout better. Can anyone comment on the look/feel comparison between the two? I can only get 'hands on' with the 780 in my local best buy but realize you need CCP to program that remote. Thanks -
post #69 of 185
I auditioned an MX-780 once but ultimately bought an R40 and it feels identical to the 780.
I briefly had an R50 but didn't like the feel, so i replaced it with the R40 and it's a big improvement. I think i commented about this in post #1.
post #70 of 185
Hi guys,
When I bought it, I was pretty sure that this R40 is a "holy grail" of all the learning remotes... well, not anymore. I've been trying to complete the programming of 7 devices on this remote, for the past week or two. I do realize that once you try to "re-learn" a new command on a key with an existing command, the next command in line gets erased... and I can live with that. All it takes is to have a "perfect" teaching session for each of the devices and you're set. If this doesn't happen (i.e. if you make one mistake), the device needs to get erased and re-programmed from the scratch. Like I said, that's not a problem at all. After so many hours spent with the R40, I can program the thing with my eyes closed. The power of the IR is amazing. The feel and button layout work very well for me... The thing seems to be built like a tank. And the LCD is really really cool. What really renders this device useless for me though, is the fact that it DOES lose (or "forgets") commands it has learned... I actually did a complete remote factory reset and re-programmed all the 7 devices yesterday morning, making sure, that all the keys work properly (at the end of session for each device I tested each single key - and they all worked the way there were intended to)... only to find out that later the same day, a power key doesn't work anymore on my HTPC device, or that the stop button doesn't work on my XBMC device... and so on... It just puts you into a continuous programming mode with this remote... I would really like to be able to use it, as I do like it very much. But at this point, the frustration level is way too high. I do have the URC WR7 and this one has not issues. The only part that sucks, is that I cannot label buttons as there's no LCD on it. Going back tot he R40 - do I have a lemon??? Is there a solution to this problem? Any responses would be greatly appreciated. Thanks.
Edited by alander - 12/30/12 at 6:16am
post #71 of 185
It just puts you into a continuous programming mode with this remote... I would really like to be able to use it, as I do like it very much. But at this point, the frustration level is way too high. I do have the URC WR7 and this one has not issues. The only part that sucks, is that I cannot label buttons as there's no LCD on it. Going back to the R40 - do I have a lemon??? Is there a solution to this problem? Any responses would be greatly appreciated. Thanks.
I think you have a lemon. Aside from the "relearn" quirk, my R40 has otherwise never forgotten or lost a command like you're describing on your unit. And i currently have 11 devices programmed into mine. All function perfectly with 100% reliability. I can't recall any other R40 (or R50) owners posting the issue that you're having with yours.
I don't know if this matters or not, but i don't use the pre-programmed device codes at all. I create all my own icons and teach it directly from the original remote.
If it had a Clone feature i'd actually buy a 2nd one to keep across the room.
I would get yours exchanged.
post #72 of 185
Is there a way to manually enter codes into the R40? Just got mine in the mail along with a Schmartz PS3IR-1000 and in the instructions for the Schmartz it says to enter the code 648 for all URC remotes but I dont see a way of doing that. I am new to these remotes and other than trying to figure out this PS3 thing I am loving it so far.
post #73 of 185
Hello everybody,
Probably a VERY BASIC question for all of you, so I apologize in advance.....
Recently picked up one of these, after my wife dropped the Harmony One in a bucket of water. Absolutely true story by the way.
Anyway, sometime over Christmas I have misplaced the Quick Start Guide, and, as you probably know, there doesn't seem to be an additional, more extensive Instruction Manual (or similar) available. I tried looking online for a copy of the Quick Start Guide - Couldn't find one.
My issue is MACRO programming. Please can someone tell me EXACTLY what buttons I need to press to record a MACRO sequence.
Some other information that may help you respond -
1. I have started to program the 6 buttons surrounding the screen with all of my devices, which are -
a) Roku 2 XS 3100x
b) Samsung 58" PN58C500 Plasma TV
c) Yamaha RX-V367 Receiver
d) Yamaha YDS-12 Ipod cradle, for Receiver.
e) Samsung BD-P1590 Blu-Ray Player
f) Nintendo Wii
g) Dish Network VIP 722HD DVR
(I know I have to finish programming these before being able to program a Macro).
2. I have all cables connected properly, and labelled at either end which device name and input socket.
3. I have created a 'cheatsheet' grid on paper that tells me exactly what devices need to be turned on / off, and what INPUT to be set to, to achieve the following actions -
a) Watch Satellite TV.
b) Watch Netflix (through Roku)
c) Watch Amazon TV (through Roku)
d) Watch Hulu (through Roku)
e) Watch DVD / BluRay
f) Listen to IPod (using Receiver 'dock')
g) Play Nintendo Wii
h) Listen to CD
4. My thought is that I'll use the 'pause' trick to use the 6 buttons (surrounding the screen) to achieve ALL of the Macro's (3. a-h, above). For example, the top-left screen-button is currently programmed to operate the Dish Network Satellite DVR, I have named it "Sat-Box", and I would like to program a Macro so that when I press it longer than half a second, it will do the following -
a) Turn on TV, and set to HDMI 2 Input (it has 3 HDMI Input's)
b) Turn on Receiver, and set to HDMI 2 Output (it has one HDMI Output and 4 HDMI Inputs)
c) Turn on DVR, and set to 'Tuner' (Don't know why this is, but it worked with the Harmony)
d) Turn off all other devices.
5. I will probably 'tweak' the Macro's after I've got these basic Macro's set-up, in a couple of weeks, after I've been using the Remote for a while. For example decide how to use the 4 color-coded "My Favorites" buttons, and build Macro's accordingly.
6. I know how to get to "Setup a new macro", but this is where I'm stuck. It asks me "On the main menu" or "Inside a device". And after this, I get completely lost. For example, EXACTLY what button do I press to turn on Receiver, and then EXACTLY what do I press to set Receiver to HDMI 2 Output? Set TV to HDMI 2 Input? Etc...?
I really appreciate you spending the time to teach me something that is probably very basic - I promise I will be a good student - You will not have to explain it to me more than once.
post #74 of 185
Originally Posted by rovernev View Post
Recently picked up one of these..... I tried looking online for a copy of the Quick Start Guide - Couldn't find one.
URC doesn't have the R40's Quick Start Guide available online, but they do have it for the older R50 which functions almost exactly the same except for a few different features so you can use it for the R40 as well.......
www.universalremote.com/resources/pdfs/R50_quick_start.pdf
It's just asking you if you want to create that Macro on one of the keys surrounding the Main Screen, or while the remote is in one of your device modes (like when you're watching satellite).
post #75 of 185
Thanks for the R50 Quick Guide. I scanned through it, and I didn't see step-by-step instructions on how to record a Macro. Here's the closest it comes:
"To setup a macro, practice with the R50 first. You need to record each step you make, so familiarize yourself with the routine then try recording it. If the routine is complicated, don’t worry. The R50 can record up to 255 steps to one button as a Macro. Just write it down first, so that it is easy for you to record."
Can anybody help with step-by-step instructions?
post #76 of 185
Thanks for the R50 Quick Guide. I scanned through it, and I didn't see step-by-step instructions on how to record a Macro.......Can anybody help with step-by-step instructions?
There really aren't any step-by-step instructions; it's more of a "learn by doing" method. It's advisable to "write a script" of all the commands you want to use to accomplish your macro. Since there are so many different ways you can "write the script" when creating a particular macro it would be difficult to tell you exactly which keys to press - we'd have to have the remote in our hands. Basically you just follow the prompts as you pluck your various commands from your various devices, then at the end of the macro you either leave the R40 in Main Screen mode or in a Device Mode.
When i set one up for a buddy he wanted his to be in Main Screen mode where he could see all his devices on page 1 of the Main screen. But i set mine up so it's always in Tivo mode as my "home device", then i created various Macros to switch from one device to another. When i first step into my man-room, i press my SYSTEM key and it's macro turns on my Plasma TV, turns on my Onkyo A/V Receiver, forces the TV to HDMI Input #2, forces the Onkyo into TV Sound mode, then puts the R40 into Tivo device mode. Pressing the SYSTEM key also turns the TV and Onkyo off.
If i want to switch from Tivo to DVD, i created a press-and-hold macro on the Red FAVORITES key that turns on the DVD player, switches the Onkyo to DVD sound mode, switches the TV to input #3 HDMI, then leaves the R40 in DVD watching mode. When i'm done watching DVD, i have a macro on the Yellow FAVORITES key to switch the TV back to the Tivo's input, turns the DVD Player off, and leaves the R40 in Tivo watching mode.
It takes some practice so just play around with it and get familiar with the steps involved in creating your macro. If you screw up you can go back and edit the macro (add or delete commands) or just delete the whole screwed up macro and start over. It's actually fairly intuitive, just remember that to switch from one device to another during the macro creation, you have to go the Main Screen to access your other devices as you build your macro.
As an example, here is my key pressing script for the macro that switches my R40 from Tivo watching mode to DVD watching mode.
I chose "Inside a Device" since this macro will be performed while i'm in Tivo watching mode.
1. Go to my Main Screen and Press the Tivo Icon key (because i want to place this macro inside my Tivo device)
2. Red FAVORITE Key (to store this Macro on this key) (you could also place this macro on a Main Screen key)
3. Pause key (to add a press-and-hold pause for this macro)
4. MAIN key (to return to my Device Icons on the Main Screen)
5. DVD Icon key (so that i can import the DVD player's POWER button's command into the macro)
6. Power key (to turn the DVD Player On)
7. Main key (to take me back to the Main Screen so that i can now see and select my TV Icon next)
8. Plasma TV Icon key (so i can get at the TV's input menu command)
9. TV's input key (to bring up my on-screen list of TV inputs)
10. #4 number key (selects my DVD Player's input which is on TV HDMI Input #4)
11. TV's Exit key (to clear the TV's input list menu from the TV's screen so it doesn't linger)
12. MAIN key (so i can now see and select my Onkyo device icon next)
13. Onkyo Icon key (to access my Onkyo's command next)
14. Onkyo's discrete DVD sound mode key (to change my Onkyo from the Tivo sound mode to the DVD sound mode)
15. MAIN key (brings up my Device Icons on the Main Screen again)
16. DVD Icon key (to leave the R40 in DVD watching mode)
17. Press DONE (to finalize and save this macro)
Then i just exit out of the setup screen. I have a similar macro on my Yellow FAVORITES key to switch back from DVD watching mode to Tivo watching mode. I have about 11 devices programmed into my R40 and so many macros that i can't remember where they all are!
post #77 of 185
Excellent, I really appreciate it. I'll play around. Thanks.
post #78 of 185
how is the ir strength??
I recently bought a Harmony ONE and will be returning it because of the weak emitters.
post #79 of 185
Originally Posted by jason978 View Post
how is the ir strength?? I recently bought a Harmony ONE and will be returning it because of the weak emitters.
I just took mine to my dining room 16 feet away from my TV and with the battery power level indicator indicating 64%, it's still controlling my Tivo and TV just fine. I can't move any farther away so i can't test it beyond 16ft.
post #80 of 185
Thanks randy,
can you point it at the ceiling or away from the device or do you have to point the remote at the device?. I can point my old 670 anywhere, even backwards and it still works. The new and so called improved harmony has to be pointed directly at the ddevice. thanks.
post #81 of 185
Thanks randy,
can you point it at the ceiling or away from the device or do you have to point the remote at the device?. I can point my old 670 anywhere, even backwards and it still works. The new and so called improved harmony has to be pointed directly at the device. thanks.
Wow, i just tried it from 10 feet away from the TV & Tivo and yes it does work when i point it at the ceiling and even when pointed backwards. It works at most angles as i wave it around in various directions, but there are some dead spots. Until now i had no idea it would do that since mine is either sitting on my desk (next to my mouse) in the corner of the man room pointing at the TV, or i hold it in my hand when we're watching from the couch. Beyond 10 feet though it has to be pointed more towards the TV & Tivo. Battery level is at 64% so maybe it would have more distance with fresher batteries.
post #82 of 185
Thanks randy,
This remote is an IR BLASTER; the R50 was also. I can bounce commands off my (drop down) movie screen and back to the projector it's so strong (the remote that came with the projector will barely work head on).
post #83 of 185
Hi Randy. First of all, I've enjoyed reading your posts over the years. I value your opinion.
I've been using MX-500s for about 8 years. I currently have two. I bought an R40, but returned it because of the "relearn" quirk (I really liked it otherwise). I'm wondering if you have a set of "rules" to help minimize this problem. If you reprogram a single button for a device, do you clear the entire device and relearn all the keys, or are there tricks to get around this? Does relearning the last key programmed on a device ever affect the following device?
On a separate topic, the Amazon description for the R40 indicates there are more than 150 favorites icons, but I only saw 60 (and 8 of these were solid colored backgrounds). Am I missing something?
I really miss the clone feature too.
post #84 of 185
Originally Posted by AndrewCowley2 View Post
Is there a fix / workaround for the issue where learning commands causes previously learnt commands on nearby buttons to be lost? This is really annoying and makes the remote almost unusable. Wondering too is this an across the board issue or do only some suffer from it?
Hi. I read that URC advice was that it is something to do with changes being stacked instead of overwritten.
The cure was said to be to delete the device and start it again...
post #85 of 185
Presuming you're talking about the issue from Post #49, i tried deleting a device and starting over but that didn't prevent the relearn quirk from happening again, so i would have been better off to just re-learn the few dropped commands instead of having to spend a ton of time re-creating the device i'd deleted. If, after i discover that a command that i just taught it caused another command to stop working, i just re-teach that lost command and it usually sticks. I think the most times i've had to re-teach a lost command is 3 then after that everything sticks. It's a minor annoyance, but i definitely wouldn't bother with deleting a whole device since for me that didn't stop the quirk.
I don't use favorites at all and i have no experience with the function. Dunno how many icons are in that function.
Edit - i just ordered a used/new condition R40 from Amazon to replace the wife's MX-500 in her den. I can make the R40 more idiot-proof, not that she's an idiot. She can oversee and operate all the life support equipment in a Pediatric ICU, but she just can't figure out how to work a universal remote control biggrin.gif
post #86 of 185
Some of you have more patience than me with the R50. I spent way too many hours putting in six devices. I did it all of them from scratch, and it would not have been that bad except for that crazy issue with the button functions moving if you make a single mistake. I noticed that if you have an unused button near by (especially downstream), the issue would not move any further. However, it was almost impossible to correct the problem in most of my devices without deleting and starting over. I am really trying to like this remote, but this issue can turn a few hours of work into a day or more. My other issue with this remote is that you can't back up your work. If the remote breaks or fails, it will be necessary to enter everything again. My MX-700 and 850 units from the past are looking better and better! I am starting to think that building all devices from scratch is probably too much work, even though you can get a fantastic result. If I was not a Mac guy and tired of dealing with the software issues, I would opt for the 780. When the hours to program the R50 are considered, the 780 would probably be a better option.
Stephen C.
post #87 of 185
.....I bought an R40, but returned it because of the "relearn" quirk (I really liked it otherwise). I'm wondering if you have a set of "rules" to help minimize this problem. If you reprogram a single button for a device, do you clear the entire device and relearn all the keys, or are there tricks to get around this? Does relearning the last key programmed on a device ever affect the following device?
I can't remember the "relearn" quirk ever losing a command on another device, just the device i was currently programming.
And URC's recommendation to delete the whole device and start over is not sound advice - i tried it and that did not prevent the "relearn" quirk from happening. Re-teaching the few lost commands eventually sticks with the first (or 2nd or 3rd) attempts, and is only a few extra key strokes which is a lot less work then deleting then re-creating a device - which doesn't work anyway.
But expounding on your question about me having any rules to get around this, i tried something new after it happened a few times while programming my new/used 2nd R40 that i just got yesterday. I noticed a pattern on this unit as well as my original unit wherein the command(s) that got lost seemed to be in the same "group" of keys that i was currently programming. I remember seeing specific "groups" of keys in the Copy/Paste advanced menu so i tried something new - i wrote down the list of keys in each of those groups, then i programmed all the Volume keys listed in the first group then exited and tested each one and they all worked. So then i programmed all the Channel keys in the 2nd group and exited, and they also all worked. Same went for the Play group and Menu group.
This is just a theory but either doing each group fully and in succession prevents this from happening, or it was just a coincidence. But even if it doesn't work, re-learning the relative few lost commands is a minor annoyance as you chase and relearn the lost commands - they eventually stick.
Here are the four Copy/Paste Key Groupings from the menu:
VOL: Vol+, Vol-, Mute
CH: Ch+, Ch-, Prev Ch, and numbers 0 through 9
PLAY: Play, Stop, Pause, Rew, FF, Record, Skip+, Skip-
MENU: Menu, Guide, Info, Exit, Select, Up, Down, Left, Right
Cloning would be handy, but in the grand scheme of things i would have still had to create and name the icons anyway (like you had to name cloned keys on the MX-500) and that takes more time than teaching the keys so i'm not missing the clone feature much anymore.
Programming this R40 is actually kinda fun, it's like a sort of customizable puzzle. I'm trying different creative ways to make the wife's new/used R40 foolproof so that if she gets her den's TV / Cable DVR / DVD Player inputs all out of whack - she often gets lost while switching inputs and powering up the DVD player etc and ends up with a black screen or ends up in the wrong device mode and can't figure out how to get things working again, so i'm devising some "Def Con" key method that she can press on master key that will take her back to "Watch Cable DVR" mode regardless of what device mode she ends up getting lost in, so that she doesn't have to get me to come straighten it out. And trying to explain it to her over the phone when i'm not there is maddening LOL.
post #88 of 185
Randy
Your comments about the group of keys are interesting. I noticed that my problem seemed to move in the direction that I taught the commands (I could be a little confused about this because the group of keys that you mentioned tended to follow each other in my programming sequence). Thus, if it was near the top of the remote it seemed to move to the next command programmed. I made an EXCEL spreadsheet of all of the commands on the R40 moving left to right and down for the most part. The issue seemed to move from the power on/off keys into the six display keys. I tried to erase all commands in the vicinity of the problem, but the issue always showed back up. The problem eventually migrated to the number keys. For me, the only solution was to delete the device and start over. However, If the problem moved to an unused button, all was well. In fact, for a couple of devices, I deleted the label of a button that was not that useful to avoid reprogramming the whole device. It was kind of fun trying to figure it out. On the good side, I can now easily program all of the buttons for a device in under ten minutes, teaching every command from the original remote. However, you can not make a mistake, or you will probably need to start over again for that device. If it was not for this one weird issue, I would love this remote. I kind of like it anyway!
Thanks for sharing your experiences with this unit!
Stephen C.
post #89 of 185
One of the comments about "getting the TV's inputs out of whack" make me think I should share a trick I use to control my TV's inputs (I don't switch hi-def sources through my AMP/Receiver).
1) I program the master power on/off keys (the 2 top most keys) with the source up/down select for my TV
2) I then copy those keys to ALL devices, so no matter which menu/device I'm in, I can check another TV input source without changing the audio, etc.
The side benefit of this (and another key point) is that I can't turn ANY device on/off from my remote (by accident).
post #90 of 185
Is anybody using a Roku 2 XS box? I use this to access Netflix, Hulu, Pandora, etc, instead of the more 'common' way of using a Blu-Ray DVD Player to access these other content-channels. Within the URC-R40 unit, Roku is listed under the "AUX" group of devices, however the (one available) code # (0565) does not work. Also, I tried the "Learn" feature, but this didn't work either. Possibly because the Roku Remote is sending a different type of signal? I think I read this somewhere....
  Back to Forum: Remote Control Area
