I've got a Logitech Z-680 speaker set that can be controlled by remote. I recently upgraded my DVR from TW and so they gave me a new remote. The new remote is a Atlas 1056B01 remote.
I'm trying to get the AUD button the remote programmed to control the Logitech speakers, but nothing seems to be working. I had the previous universal remote from TW programmed to control them, so I know it isn't totally impossible. Unfortunately I wasn't thinking and didn't grab the programming codes off the old remote before the tech left.
I found this old thread that is for a different logitech speaker system and the 1055 remote, but it didn't seem to work: http://www.avsforum.com/avs-vb/showt...php?p=15394434
I'm not sure if the problem is the different remote or the different speaker setup. It kind of acts like the remote doesn't like the 00117 code - either that or the way to enter the code is different on this remote.
If anyone has any insights or solutions it would be greatly appreciated.
Other than getting my power button to work, I'm not sure that I'd want to do much customization - it does most of what I need with the standard codes.
