AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › audio solution for viewsonic pled w500
post #1 of 10
i want to buy pled w500 projector but does anyone got solution how to output the audio to my onkyo receiver or headphones.tried to buy acer k330 but it is soldout everywhere.
thanks
post #2 of 10
bump
post #3 of 10
Have a little patience. You posted in the middle of the night and you expect an answer immediately? Do you think these forums are actually monitored 24/7?
To answer your question, all I had to do was look at the manual online, something you should do when researching projectors. What you want to do is not possible. The projector does NOT have an Audio OUT. To use headsets or direct the audio to your receiver, you will have to connect the audio from the SOURCE to the receiver.
post #4 of 10
i know it doesn't have audio out but it does have audio in. i can output the ps3 through optical output but if i want to output the sound when i play from my usb drive.is there any device that can attach with the usb and sound output.since acer k330 has output but it is sold-out everywhere.
if i buy a vp3d1 will it help to output the sound.
thank you.
post #5 of 10
Yes, it's called a computer.
post #6 of 10
post #7 of 10
I wonder if a cheap usb sound "card" could be made to work
they are a quick fix for dead sound on MOBOs
http://www.google.com/products/catal...d=0CIUCEPMCMAg
post #8 of 10
thanks that definitely looks promising.i was looking for something like this.
post #9 of 10
If you had stated all of this in your FIRST post, I might have had more helpful information. All I had to go on was that you wanted to output the audio (no source specified) to your receiver and that the projector you wanted to get but was sold out had audio out.
I'm delighted you finally got some useful tips, but next time, the more information you provide, the better we can help.
thank you.
post #10 of 10
try hd player egrate s900 on ebay
