Ave,
So here's my story. We just bought a new home and as of right now we don't have the option of a large sized area to create a home theater room. So we'd like to use one of the bedrooms as a Home Theater for the time being.
Unfortunately, this extra bedroom is somewhat small. The width from the back wall to the front wall is about 9 & half feet, and that's all the throwing distance that I'm going to have. What I'd like to do is setup the projector high up on the cieling on the back wall and have a small seating arrangement underneat the projector with the front wall for the Screen.
This image below can explain what I mean.
The window will be completely darkened out and I won't have any light issues; the room can be closed into a fully dark room.
As you can see, I don't have a lot of room to play with. I would really, really like to get anywhere between 75" ~ 80" wide screen; however - with that throw distance, I'm not sure if it's possible.
My wife & I love big screens; we bought the Samsung PN63C8000 which is a 63" 3D Plasma -- and absolutely love it. But after seeing some Projector setups, we both wanted to take it a step further. The thing is, if that room will only allow me a 65" screen, or something in that vicinity, I'm not sure if the Projector is going to be worth it. But if I can get a little more real estate - then it's totally worth it.
Keep in mind - at some point we plan to build an extension to the property & build a nice, bigger, dedicated HT room. So the same projector/setup will eventually make it's way to a bigger space. But for now we need to somehow make this room work.
I haven't completed my research on which projector to get; it'll have to be a 3D Projector and I'm looking at everything from Epson 5010 to Mitsubishi HC7800D to Sony's VPL line and Optoma as well. I can easily spend anywhere between $3K ~ $3.5K. So whatever best I can get in that price will work.
But right now my bigger concern is a) It is possible & worth considering a projector setup in this room; b) What kind of a screen size can I possibly get; and c) Considering the size of the room, will we be able to enjoy & get good watching experience using a Projector?
I'll appreciate any advice & recommendations. Especially from people here who may have a small room projector setup.
Thanks!!
Thanks!!
