Originally Posted by rontalley
As long as I can receive the 3D signal on the 3D capable projector, I don't care if my TV can't read the signal, truthfully, it doesn't have to be on at all! I just want to be able to have the ability to switch from multiple HDMI sources, extract the multichannel audio and send it to spdif or optical and output the HDMI signal to two sources all at the same time. After reading further, it appears that the Matrix box I listed earlier will do this but will not send the same source signal to two displays at the same time. It appears that it will only do 2 sources to 2 separate outputs at a time.
I am even ok with this because my projector screen will be pulled down over my TV so I can only watch one a time anyway but would still like the ability to have both "sinks" display the same 2D information.
Any recommendations for a device like this?
I am even ok with this because my projector screen will be pulled down over my TV so I can only watch one a time anyway but would still like the ability to have both "sinks" display the same 2D information.Any recommendations for a device like this?
Then you need a unit that does EDID spoofing. I believe almost all of the Octava units will do that (Joe can correct me, if it is all of the units).
