I am in the process of buying an A/V system for a cottage and I have what I imagine is a common situation for which I have not been able to find a simple solution. I figured that if anyone knows an answer to this dilemma it will be here on AVS.
I am looking to have a home theatre set up (pretty standard) in the media room as well as outdoor speakers run to my back deck. I would like the two areas to operate as separate zones (both able to be used at the same time). Seems simple enough... The catch, I would like to be able to play any of my audio sources (and specifically my Sat TV and Apple TV) on both the primary and secondary zone. I have tried this in my home system with no luck as the second zone only accepts analogue sources. I figured that would be a quirk of my older Amp but my reading here suggests this is not the case.
Is there a simple solution to this that I am missing? Any help would be GREATLY appreciated.
Thanks. HC22.
Thanks. HC22.
