Hello all!
After tons of research (most of it here) I purchased a HD70 a few years back on sale and have loved it. Well.....it bit the dust. (which is bad) but I had the protection plan (which was good) BUT BB only wants to give me $440 towards a new projector (which is bad).
I was able to (after 3 or so hours) convince the manager to at least get me to a 720p projector (they originally wanted to replace my HD70 with a vivitek 4:3 office projector) and I wanted to make sure I was going to be happy.
So currently, they are ordering me a Optima HD66. I'm not finding a ton on the projector, except that it might be a HD65 with the addition of 3d (that some review say, isn't 3d even though some say it is)
So, my question is : Is the HD66 going to be comparable / better / worse than my beloved HD70? Because there is the option to take it as a Gift Card and then pay the difference (LOTS) to jump to the HD20, or some other option.
Also, a while back I got an extra bulb for the HD70, are they compatible?
I'm in a fully light controlled room, used mainly for video games (xbox 360 via HDMI) and some movies.
Thank you!
Thank you!
