AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Site running slow?
Site running slow?
post #1 of 8
Hi guys - I've noticed over the past week or so that it the site has been rather sluggish. As one example, it can take up to 10 seconds for a post to be submitted and the page refreshed.
I am sure there is nothing wrong with my connectivity. I suppose if its not the AVS servers or your data center that there may be an issue somewhere in the route.
Is anyone else experiencing this or are you aware of any such issues? Do you keep performance data on load times and can you see any issues? Thanks.
post #2 of 8
It's loading as fast as usual for me.
post #3 of 8
Same thing here with FF with all cookies, etc. intact or cleared. Up to 30 sec to Submit an edited post.
post #4 of 8
OK glad its not just my imagination. I've experienced this for a while now - just thinking maybe they were doing maintenance around the holidays. But now that I see it is still slow I thought I would ask.
It seems to be somewhat intermittent. Like when bringing up a topic or going to the next page in a topic it is sometimes quite slow and I can see in my browser status bar messages like "connecting..." and "waiting for..." and back and forth with that several times before it actually loads. Whereas normally its so fast you aren't able to read such messages.
post #5 of 8
I am not seeing it at all and I am on a Hughes Sat connection from our motor coach. Run a trace route and see if you can see any issues along the path.
post #6 of 8
The above post...
Page generated in 0.12223697 seconds with 12 queries Server Loads...0.70 : 0.92 : 1.02 | Uncached Templates: None
So it does not seem to be the servers that I can see at this time.
post #7 of 8
Originally Posted by David Bott View Post
The above post...
Right now the site is very responsive. It comes and goes. It is probably not affecting most or you would be well aware of it. Regarding the page generated in x seconds - that tells us the server load is fine but of course does not include any network latency which is likely the culprit here.
post #8 of 8
Yes, that was my point and the reason to run a trace route.
  Back to Forum: Forum Operations Center
