So if you're using DTS: NeoX, and you're playing a blu ray that is decoded say in Dolby Digital HD, that will work fine?
DTS: NeoX is capable of decoding whatever type of soundtrack is thrown at it and modifying that track to make it output up to as many as 11 channels of surround sound?
I'm new to learning about this sort of thing, and I'm just so used to watching movies on blu ray that are either decoded in DDHD, or DTSHD etc.
So if you're running an AVR that has DTS: NeoX, and you're setup for say the following... L,C,R,SR,SL,RR,LR and heights, you can just leave your AVR on the DTS:Neo X setting, and it will decode the material into your 9 channels as intended for that many channels? Irregardless of whether the soundtrack is DD, or DTS etc???????
Sorry for the long winding question!
