AVS › AVS Forum › Display Devices › Rear Projection Units › Question on Mitsubishi WD-62627
post #1 of 4
Hey guys, I am new to the forum and had a question on my Mitsubishi DLP WD-62627. There is a dark transparent line at the top of the screen, it is only about 1/8" on the top left and about 1 1/2" on the top right and goes the full width of the screen. It has been on there for several months now, and not sure why? I just replaced the lamp, as it fried a couple days ago and there is no change, other than the line seems more noticeable, I guess the new lamp is brighter or something. Anyways, just wanted to see if anyone knew what this was or how to fix it. I guess it could mean that she is on her last leg and I should start saving for a new one. Any help would be appreciated. I have attached a picture, hopefully it help explain. Thanks
Eric
post #2 of 4
No ideas on this? Does anyone know where else I could go to post up the question. Thanks again.
Eric
post #3 of 4
Never seen light tunnel problems reported with any Mits, but you never know. If I had to guess, I would check the lens path behind the screen. Remove the screen and see if something has fallen into the projection area.
post #4 of 4
Thanks for the reply. Any tips on how to correctly remove the screen without causing any damage?
  Back to Forum: Rear Projection Units
