Have to disagree with coderguy's flat claim that anything below 12 ftL is somehow across the board unacceptable.
I watch on a BOC screen (around .8 gain) with a calibrated Mits HC4000 in Low lamp; 16:9 is at 110". Coderguy's calculator says I'm getting 6-something ftL (1000 hours on lamp). When I watch 2.35 stuff, my CIH screen is 10.5' wide which gives me an effective 16:9 image of 142" and around 4 ftL.
Not once has anyone said the picture seems dim or anything. My friends spend more time at another friend's watching his 106" Studiotek 130 1.3 gain screen with his JVC RS35 in a 100% dedicated batcave of a theater, a much brighter setup than mine, and never once have they had a single complaint about my picture, and in fact have said they prefer the larger screen. I think his looks significantly better, but that's more due to the far superior blacks than the difference in brightness.
I find most movies look excellent. There are some dimmer movies -- Half-Blood Prince, The Road, and oddly 21 Jump Streeet -- where I find myself really wishing for more brightness, but really these are the exception rather than the rule.
Having said all that, I am in fact looking to upgrade to a screen paint with some brightness improvements to get the most out of my projector, but a simple 1.0 gain flat white could conceivably be the route I end up going in the end as well.
The notion that you can't possibly be 100% satisfied with the 8700 with anything less than a Da-Lite 2.5 gain is really ridiculous. Look all over this forum and you will find loads of people getting less than 12 ftL, sometimes much much less, and I'm pretty confident that we are, on the whole, an exceptionally picky bunch.
Not to mention the fact that for a 145" screen, the difference between the 5010 in best mode, low lamp, and the 8700UB in best mode, low lamp, is only about 1 ftL. You might not even notice that difference in a side by side comparison.
