Hi all,
I've searched but could not find a clear answer on the high gain paint mixtures. I've seen recommendations that the S-I-L-V-E-R mixture has the highest gain. Is this the same as the Silver Fire 2.5?
I am looking at doing an AT Screen using the SMX material that I have on hand. Screen size is going to be 132in wide 2.35 screen. Room is completely light controlled so I don't need any ambiant light control.
Even though the Sony HW-30 is powerful, its not going to be enough for this large screen and especially if 3D is going to be used.
So I'm looking at improving the SMX and paining it with a high gain screen mix. According to MM in another thread the AT properties are not affected if care is taken in the spraying. I have on hand a large compressor and two paint guns that I have never used.
Projector is going to be ceiling mounted (soffit at the back of the room). Can I get 2.5 gain screen with the Silver fire 2.5?
But I'll keep an eye on the Postings and my PM box...be certain of that.
