Would like to set up an equalizer for our church PA system. The system is pretty good with adequate power, mains and sub but want to improve it further. Suspect the best way is to test the system using calibrated mic, and a software package and EQ as needed.
What package would you recommend. Is simple frequency response measurements all that is needed?
I am an engineer but audio is an old hobby.
