Hi all. I'm sure this has been asked, but I haven't been able to find much info on this in my searches. I am looking between a hsu uls 15 and a rythmik f15hp. The hsu uses a paper driver, the rythmik uses aluminum. Does cone material make any difference in performance, longevity, etc on a sub ? I know different companies have used different materials, and I'm wondering if it should be a consideration. Thanks!
Featured Stories
cone material
AVS Top Picks
post #2 of 53
1/5/12 at 9:57am
- sputter1
- Trader Feedback: 0
- offline
- 1,248 Posts. Joined 1/2010
- Select All Posts By This User
None that i'm aware of, it's factored into the design. I have seen comments that some people can "hear" a difference but as far as I know there is no solid proof of it.
P.S. aluminum or kevlar sounds cooler though.
post #3 of 53
1/5/12 at 10:08am
- SaviorMachine
- offline
- 1,050 Posts. Joined 11/2010
Some materials, like aluminum or resin-reinforced Kevlar, flex less at high output and low extension than some commonly used papers; reduced flexion results in higher quality sound. On the other hand, paper is of course very lightweight, so some manufacturers use paper cones with the intention of providing a faster, more accurate response to transients and higher-frequency signals. For example, Rythmik offer a choice of paper or aluminum for at least one of their high-end sub models.
post #4 of 53
1/5/12 at 10:13am
- Scott Simonian
- I've called it 'The P45'
- offline
- 10,437 Posts. Joined 10/2001
This... yes.
This... no.
Cone material has no impact on SQ with a subwoofer, whatsoever. If the cone flexes and produces distortion, it isn't a good sub driver to begin with.
post #5 of 53
1/5/12 at 10:25am
- monomer
- Trader Feedback: +3
- offline
- 1,767 Posts. Joined 4/2002
So what you're saying is a cone made from lead would sound no different than an aluminum cone provided the lead doesn't flex? Somehow that just sounds ridiculous don't you think? All else being equal cone mass does have some effect upon accuracy and thus the "sound signature" reproduced. Basically a light mass with a high degree of stiffness is what's preferred, unfortunately these two properties are often found to be at odds and so designers seek the best compromises in cone material for the application.
post #6 of 53
1/5/12 at 10:42am
- Scott Simonian
- offline
Well duh.
If it is improperly designed from the get-go, it will not be good.
Stiffness and strength are important, always. The overall 'lightness' or lack of weight is part of the design. A pro style 15/18" midbass woofer will have a lighter moving mass than a 15/18" subwoofer driver. This doesn't affect the "speed" or quickness of the driver at all, it affects the sensitivity within a certain bandwidth. The heavier sub driver will be more sensitive down low with a lower rated resonant frequency. Whether it is made from aluminum, titanium, carbon fiber, kevlar or paper makes no difference.
post #7 of 53
1/5/12 at 10:43am
- SaviorMachine
- offline
You have a lot of posts and you usually seem to know what you're talking about, whereas I just started paying attention to this stuff and learn something new almost every day. That said, I'm only paraphrasing Brian Ding (user Rythmik), whose experience certainly exceeds mine.
post #8 of 53
1/5/12 at 10:53am
- Scott Simonian
- offline
I took a quick peek over at their website. Saw their 'GR' branded drivers with this description. Sorry to tell you but it is all marketing mumbo-jumbo.
post #9 of 53
1/5/12 at 10:56am
- Theresa
- offline
- 2,291 Posts. Joined 11/2010
Exactly. Don't judge a sub by the material its made of, instead learn about the difference in sub motors (the whole mechanical system of a speaker).
post #10 of 53
1/5/12 at 11:04am
- monomer
- offline
Its simple really... aluminum will flex less and the lighter mass paper will simply stop faster (less overshoot). The aluminum will have tha advanatges down low where cone distortion would affect accuracy whereas the paper will have an advantage in accuracy due to ringing in the higher frequencies... bottom line, they will not perform/measure/sound exactly the same under all conditions, all else being equal.
post #11 of 53
1/5/12 at 11:12am
- Scott Simonian
- offline
No, sorry but that's mostly incorrect. The effects you bring up are not exclusive to the material, itself. One has to pay attention to the electro-mechanical properties of said driver.
The effect you are thinking is related to the Qts of the driver or Qtc of the total system. A higher rating, especially Qtc ratings of 1 or higher will have excessive ringing from stored energy. This has absolutely NOTHING to do with the material of the cone.
Read this: http://www.data-bass.com/data?page=knowhow&type=1
post #12 of 53
1/5/12 at 11:52am
Well, the paper is from a renewable source, biodegradable, and recyclable, while aluminum is mostly just recyclable.
If your drunk friend comes over and shoots your kevlar lined subwoofer, you won't have a whole in it.
Ok, so I'm being cynical 'cause it mostly depends on what a manufacturer "knows best" with designing subs. Now, if your subwoofer catches on fire, you WANT it to be Aluminum, not paper
Wow I got way more thank I bargained for here. :-) so far what I'm hearing is IF there is a difference in sound between material, it's minimal and shouldn't be a big concern. At least not for someone like me that doesn't necessarily have a refined palate in terms of ability to tell minute differences.
Any input on the other part of my question. Is there any difference in longevity or durability between driver materials?
post #14 of 53
1/5/12 at 11:55am
- Scott Simonian
- offline
No. There will be zero difference in SQ, not minute, no difference. Especially with a subwoofer. Golden-eared 'audiophiles' that claim that one sub sounds better than another based on cone material alone is living in fantasy land.
Longevity? Same for both. Don't pick your sub based on the cone material. Pick your sub based on performance/price/size and all that important stuff.
post #15 of 53
1/5/12 at 12:12pm
I would say enclosure design is way more significant than the cone, at least if you buy the woofer without it already being in one.
post #16 of 53
1/5/12 at 12:17pm
- monomer
- offline
Perhaps you didn't read my posting carefully enough... "they will not perform/measure/sound exactly the same under all conditions, all else being equal." If what you are proposing is that no relationship exists between the cone's moving mass and Qts then we have no need for further discussion as we have a fundamental disagreement. If on the other hand you do agree that a reduced cone mass (all else remaining the same) results in a decrease in Qts then I don't understand why you think it won't have any effect on ringing. Remember we are not talking about changing system parameters to accomodate this change in cone material... because that changes the whole discussion to where there is no foundation to discuss anything then.
post #17 of 53
1/5/12 at 12:19pm
- sputter1
- offline
post #18 of 53
1/5/12 at 12:22pm
- monomer
- offline
So a damp basement theater would have no effect on the longevity of paper (even treated paper) over aluminum? This just keeps getting weirder with each additional posting. I think I'll go walk my dogs... at least that's something that makes sense to me.
post #19 of 53
1/5/12 at 12:32pm
- sputter1
- offline
Originally Posted by monomer
Perhaps you didn't read my posting carefully enough... "they will not perform/measure/sound exactly the same under all conditions, all else being equal." If what you are proposing is that no relationship exists between the cone's moving mass and Qts then we have no need for further discussion as we have a fundamental disagreement. If on the other hand you do agree that a reduced cone mass (all else remaining the same) results in a decrease in Qts then I don't understand why you think it won't have any effect on ringing. Remember we are not talking about changing system parameters to accomodate this change in cone material... because that changes the whole discussion to where there is no foundation to discuss anything.
The question was "The hsu uses a paper driver, the rythmik uses aluminum. Does cone material make any difference in performance, longevity, etc on a sub ? I know different companies have used different materials, and I'm wondering if it should be a consideration. Thanks!
The answer is no. The question wasn't the use of lead, wet basements or end of days. I hope you went for a long walk...
P.S. if it's that damp in your HT room i'd be concerned about the electronics.
post #20 of 53
1/5/12 at 12:43pm
The guy's asking about performance. Different cones will be different, and change the woofer T/S parameters, but to the end user--unless the subwoofer design is garbage, then there isn't.
What you need to focus on more is reviews that take into consideration frequency sweeps of both subs.
post #21 of 53
1/5/12 at 12:44pm
If you got a wet basement, than aluminum, because like I said, you won't want paper when your subwoofer catches on fire
post #22 of 53
1/5/12 at 12:49pm
- sputter1
- offline
post #23 of 53
1/5/12 at 1:46pm
- kwarny
- offline
- 281 Posts. Joined 12/2009
The motor, surround, spider, and the inductance related to the mass (depending how high to crossover), and thermal properties matter more than cone material.
However, after pushing on tons of drivers, paper always seems to have some give. This probably matters more at higher frequencies. Too bad I can't find some high definition videos recorded around 1000 fps.
post #24 of 53
1/5/12 at 1:57pm
- Scott Simonian
- offline
I know what you're trying to do but it has nothing to do with the question at hand. You're just being silly now.
Damp basement. Lulz!
post #25 of 53
1/5/12 at 1:58pm
- monomer
- offline
The denial of this posting above is what I was responding to... maybe you missed me posting the quotes in each of my posting of what and who I was specifically referring to. I can't find fault with the statement above as its written and I don't think Rythmik's description of its comparison of its offerings within the same cab and amp is mumbo-jumbo sales talk either.
Face it, with enough money and know-how some people I guess could turn a Hummer into a vehicle with reasonable slalom times regardless of its total mass but that still won't make it handle like a true sports car. I do think some designers choose paper because of its lighter mass (though choice could also be made for other reasons as well, like cost) if that were not the case then I'd suspect you'd see a lot of exotic materials being used for woofers and mid-range drivers as well. "if it were designed correctly" works only if its actually possible to do within reasonably constraints and then you're right the whole discussion of which will sound better makes any discussion moot but that's NOT the case with Rythmic as discussion of the difference between drivers includes the assumption that all else remains equal and so the snide remark about it being "sales mumbo-jumbo" is uncalled for.
post #26 of 53
1/5/12 at 2:07pm
- monomer
- offline
Apparently you've never had to re-cone a paper driver that was kept in the basement for more than a decade and worse... I have. I search for and buy vintage speakers for my theaters. Some people do have basement theaters (one of ours is) and keep their equipment for more than 5 years. A serious consideration? probably not, still you should probably have prefaced your statement with something like "if you're not planning on keeping it more than 10 years..." You're jumping on other people's postings by taking things out of context, however you don't seem to like it when some else does it to you.
'nough said, I believe I made my point. I'm outta here.
post #27 of 53
1/5/12 at 2:23pm
- Scott Simonian
- offline
Look, if you're keeping perishable valuables in a damp basement... you need to re-think how you're doing things. I'm sorry.
First hand experience: I've got a paper coned 15" sub (with foam surround) that I've had for 10 years now. Looks exactly the same as the day I bought. Run the crap out of it too. Gets daily use. Now... I don't keep it in a damp storage area though.
And whose posts am I jumping on out of context? lolwut.
I'm just trying to help the OP and any others with the same question. All you're doing is confusing people with misinformation.
post #28 of 53
1/5/12 at 2:24pm
Actually, JVC came up with the best cone material ever. The cones were made of very thin strips of wood soaked in saki. The sound quality was excellent.
JVC makes speakers with this material, but their subwoofer cone uses pulp along with Kapok fibre, and Aramid fibre.
http://www.jvc.eu/woodcone/specifica...x.html#speaker
post #29 of 53
1/5/12 at 2:35pm
- cschang
- listen for yourself
- offline
- 14,356 Posts. Joined 3/2003
If you think he is confusing people, I think you are as well.
The two of you are looking at the issue with two different contexts...each valid.
post #30 of 53
1/5/12 at 2:41pm
- Scott Simonian
- offline
Back to Forum: Subwoofers, Bass, and Transducers
- cone material
AVS Top Picks
Currently, there are 1125 Active Users
(131 Members and 994 Guests)
Recent Discussions
- › "Official" Audyssey thread (FAQ in post #1) 3 minutes ago
- › 2013 Formula 1 in HD 3 minutes ago
- › URGENT complex vga to coax to projector 5 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 6 minutes ago
- › Official Cary Cinema 11a/11v Owner's Thread 8 minutes ago
- › New York, NY - OTA 12 minutes ago
- › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ 13 minutes ago
- › Official OPPO BDP-103 Owner's Thread 13 minutes ago
- › Official Samsung UNXXD8000 Owners' Thread 13 minutes ago
- › Apple TV owners' thread. 14 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
